Re: Worm Gear Gearbox
The worms we used last year were 35:1 on the back of another transmission. I don't recall the ratio for the Bosch tranny we used however. We wanted an extremely high torque setup for our application though.
Pete |
Boston gear also produces stock worm drive gear boxes, they're really efficient for worm drives and are quite heavy duty. we used one in our drive train last year and it worked beautiful. Picture Here. I beleive these were a 20 to 1 reduction and these had no backdrive. -Pat |
If they feel that a purchased gearbox will meet their needs better than one that they designed and built themselves, then they should by all means go for it. If they feel that they want the experience of designing and building their own, and have a unique design that they feel would meet their needs, then they should go ahead and do it. The decision to buy or build is a matter of what each team feels is best for them. For more thoughts on the matter... this thread. -- Jaine |
Most people talk about building gearboxes for custom functions that an off the shelf one wouldn't fit for, or more commonly for a shifting transmisson that is difficult and expensive to obtain off the shelf. Or was, at any rate. See: Nothing But Dewalts |
In the case of off the shelf worm gear transmission, aka speed reducers, a COTS part is much heavier than a custom one. My experience with these is that they designed for heavy machinery and not the applications that we have.
One of the best off the shelf transmission choices 177 has made in the last few years was to get the trailer jack the chip was designed for and use that to power our shoulder in 2003. There are lots of good Commercial Off The Shelf parts if you know where to look. |
341 used a worm gear gearbox last year- we had a CIM geared down to match the drill motor on both sides, she wasn't as fast as we would have liked her to be (efficiency loss), but the entire year we never got pushed once- many times we met teams with much more powerful transmissions and they couldn't budge us, our frame got really beat up from that
but seeing as our main strategy was to hang quickly from the ground, winch up to the platform, and move back and forth on the platform, it was nice to know nobody could push us. I personally am a fan of the multi-speed gearboxes over this worm gear gearbox, but if there was ever a game where you want to be a unmovable rock, like if you have to guard something, this gearbox is your man. |
Does anybody have any links to information for calculating worm gear strength?
#10
What are "starts"? The number of threads? I thought the number of threads was equivalent to the number of teeth so more threads is less reduction (and i would assume more efficient)
#12
If you look at the side of the worm, you should see the places where thread starts, that's a "start". The number of starts will change the gear ratio. i refer you to Paul's post. Quote:
#13
Yes, you are correct. I got just about everything back wards. In an attempt to make up for it, Here is a decent link that some pretty good info on worms... http://www.bostongear.com/pdf/gear_theory.pdf Pages 13 and 14
#14
On the shoulder joint of our elbow for last year's TechnoKat robot, we used a 40 tooth worm gear (Martin # W1240) and a single threaded worm gear (Martin # WG12). This design worked well, except when the arm would bounce or hit something. The teeth on the worm gear would shear. If we ever need to use this sort gearing again for an arm, we will need to do two things: 1. use a gear with larger teeth 2. provide more of a counterbalance for this same sort of joint Andy B. |
#15
*make sure you get the correct material properties as different treatments can change properties(case hardening etc.) Last edited by Jizvonius : 07-01-2005 at 12:59. |
| gears | Michael Leicht | Inventor | 12 | 16-09-2004 10:52 |
| Reverse Gear | FizMan | Technical Discussion | 12 | 26-04-2004 01:29 |
| Van Door Worm Gear | Jim Giacchi | Motors | 4 | 16-12-2003 09:35 |
| what's your most important drive train advice? | Ken Leung | Technical Discussion | 42 | 07-01-2003 09:58 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
