Go to Post Remember there are many eyes watching and often you are judged by what you say and how you say it. - Mike Martus [more]
Unread 07-01-2005, 14:01
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
Re: Worm Gear Gearbox
I definitley do not think I could do my own calculation for teeth strength. It's far more complicated then simply shear strength for that material. There are multiple engagement points at a given time, and even just calculating the area being sheared isn't simple. I need to know this for design purposes, so I can't wait to receive the part and any info it comes with. None of the gear supplier websites I have checked list the formula.
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 07-01-2005, 14:30
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
Yes you can... well, you can do some rough calculations. Stock Drive Products has a very good technical catolog section where you can follow instructions to figure gear strength (page T78). These calculations can be used as ball park figures to get you close when choosing your gear pitch.
When it comes to dynamic and shock loading, the engineering gets waaay more complicated. For our applications in FIRST robots, I suggest using the gear strength calculations linked above at the Stock Drive website. Depending on what you will be doing with your gears, you can then put in a safety factor to absorb dynamic and shock situations.
Andy B.
Unread 07-01-2005, 14:43
Fold em oval!
I've read SDP's technical section and I still cannot find any information for worm gears. Even if the gear always breaks before the worm, the calculations are not comparable because the number of meshing teeth is very different and worm gears often have a sort of concave curve in the tooth to increase mesh that further changes the mechanics.
Team 1257
gears Michael Leicht Inventor 12 16-09-2004 10:52
Reverse Gear FizMan Technical Discussion 12 26-04-2004 01:29
Van Door Worm Gear Jim Giacchi Motors 4 16-12-2003 09:35
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
