Go to Post If you always do what you’ve always done, you’ll always get what you’ve always gotten. - rourke [more]
Unread 04-01-2005, 02:03
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Processing data quickly in autonomous
I'm working on some code that requires processing data more frequently than every 26.2ms. In driver-controlled mode, this is not a problem, because I can use Process_Data_From_Local_IO(). However, the autonomous function waits for statusflag.NEW_SPI_DATA before every loop. Is there any reason that I can't put a call to Process_Data_From_Local_IO() outside of that if statement? I can't imagine why it wouldn't work, but I want to make sure that it's not going to do bad things if I do.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 04-01-2005, 02:40
Tom Saxton's Avatar
Tom Saxton Tom Saxton is offline
no team (Issaquah Robotics Society)
Tom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud of
Re: Processing data quickly in autonomous
Yeah, we did that last year, it worked great. You can also use interrupts, which we used for counting encoder ticks.
Tom Saxton
http://www.idleloop.com/
Unread 04-01-2005, 05:29
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Yeah, interrupts are the only way to go for encoders. However, the interrupt handler is a bad place to be doing math for other sensors. Thanks for the info... being able to process data quickly in autonomous will help immensely.
_
Unread 04-01-2005, 14:44
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
Actually, the call to Process_Data_From_Local_IO() IS outside of the if statement. And there is no waiting going on. The main loop simply checks the statusflag.NEW_SPI_DATA flag to see if new data is available from the master microprocessor. (It only reads memory. I doesn't make a function call.) If there is data available, it is processed, and then regardless of whether there was NEW_SPI_DATA available, it calls Process_Data_From_Local_IO.
[edit]
Sorry. I missed that you were talking about autonomous mode. I'll get back to you on that (if someone else doesn't beat me to it.)
[/edit]
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 04-01-2005, 14:45
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
I tried to fix that, but I seemed to have failed. See this post: http://www.chiefdelphi.com/forums/sh...threadid=32073
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
heres the code. y this not working omega Programming 16 31-03-2004 15:18
inputting data for autonomous mode Lou Programming 2 16-02-2004 22:26
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
