Go to Post We don't use fancy tools like that, but we might need some wood glue or something :) - MrForbes [more]
Unread 04-01-2005, 13:52
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
Rewriting main loop
I want to rewrite the main loop so that the program enters one of the two possible 26.2ms loop functions (User_Autonomous_Code() and Process_Data_From_Master_uP()) from the same place in the code. As it is, when the code enters autonomous mode, it stays in User_Autonomous_Code() until autonomous mode is unset. The main reason I'd like to change this is so that I can have a single counter counting 26.2ms cycles, rather than one in each function. Secondly, its much more logical to do it this way.
I tried to implement my method, but I get some inexplicable problem where User_Initialization() (which should be called prior to any of my changes) is not getting called, and consequently, the rest of the program cannot run. Does the master processor detect my changes and decide they are illegal or something? Why is the code written like this in the first place?
The changes I made:
in main.c replace
Code:
    while (1)   /* This loop will repeat indefinitely. */
  #ifdef _SIMULATOR
  	statusflag.NEW_SPI_DATA = 1;
  #endif
  	if (statusflag.NEW_SPI_DATA)	  /* 26.2ms loop area */
 {								 /* I'm slow! I only execute every 26.2ms because */
 									 /* that's how fast the Master uP gives me data. */
  	  Process_Data_From_Master_uP();  /* You edit this in user_routines.c */
  	  if (autonomous_mode)		    /* DO NOT CHANGE! */
 	 User_Autonomous_Code();		/* You edit this in user_routines_fast.c */
  	Process_Data_From_Local_IO();	 /* You edit this in user_routines_fast.c */
 									 /* I'm fast! I execute during every loop.*/
    } /* while (1) */
  }  /* END of Main */
with
Code:
   #ifdef _SIMULATOR
   #endif
   	  else
   /*counter++; can go here*/
     } /* while (1) */
   }  /* END of Main */
In user_routines_fast.c replace
Code:
  while (autonomous_mode)   /* DO NOT CHANGE! */
   	    Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
   		/* Add your own autonomous code here. */
   		Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
   	    Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
with
Code:
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 04-01-2005, 16:00
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Rewriting main loop
Your code looks fine. There is no magic check to see if you've changed anything in main.c. Lots of teams have rewritten main.c without issues. All the teams I mentor modify main.c for this and a variety of other reasons as well.
I'll see if I can find some past threads on this topic. [edit]http://www.chiefdelphi.com/forums/sh...ad.php?t=24590
Since the call to User_Initialization comes before the loop you posted I suspect other problems.
Here's one stripped down version. For clarity I removed some lines that delayed all action until the sensors stabilize after power-up, resets autonomous upon disable, and a couple of other specialized routine calls like conversion from 0->254 to -127->127. The Put/Getdata calls are also brought into main.c instead of being repeated elsewhere, so User_Autonomous() is a normal routine.
Code:
void main (void)
#ifdef UNCHANGEABLE_DEFINITION_AREA
IFI_Initialization ();		/* DO NOT CHANGE! */
#endif
User_Initialization();		/* You edit this in user_routines.c */
statusflag.NEW_SPI_DATA = 0; /* DO NOT CHANGE! */
#ifdef _SIMULATOR
#endif
	 Getdata(&rxdata); /* Get fresh data from the master microprocessor. */
	 Process_Data_From_Master_uP(); // Modified to only handle slow loop sensor stuff
	 if (competition_mode) // Robot is disabled
		 Gyro(); // Initialize gyro assumes FRC is powered up only when robot is in position
	 else if (autonomous_mode) // Robot is in autonomous
	 else // Robot is in normal human driver mode
		User_Driver(); // Joystick driving
	 Putdata(&txdata);			 /* DO NOT CHANGE! */
} /* while (1) */
} /* END of Main */
Unread 04-01-2005, 17:47
Fold em oval!
I guess I'll look for some typo or something somewhere. I think I will also move put and getdata() there, too.
Team 1257
Unread 04-01-2005, 18:05
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
What exactly are the errors you get? It looks like this code is fine to me. If you do get it working, post it back up here (or on the code repository! ). I'd like to use it. (And I don't want to have to figure this out as well...)
Unread 04-01-2005, 18:35
Fold em oval!
That wasn't an actual copy of the code I tried to compile, so I imagine there was some small error somewhere in my code.. I just quickly rewrote the changes for the post (it's really just deleting some stuff and moving a single line).
Team 1257
Rules for hanging, using a loop over the end of the bar caffel Rules/Strategy 10 04-06-2004 15:04
What is going to be your team's main strategy? Matt Attallah Chit-Chat 5 06-04-2004 22:34
Actual execution time measurement Dan Technical Discussion 5 24-03-2003 11:36
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
main driver Kaitlin Palmer Off-Season Events 0 09-04-2002 21:26
