Go to Post Aim for the stars – you just might hit a planet. - Leo M [more]
Unread 06-01-2005, 23:23
themaxim themaxim is offline
themaxim can only hope to improve
Programming Code
I have red the poll about your most popular programming code. and im sorry for being naive on the topic because I'm new, but what is the standard code for programming the robots? I'm new to programming, and I want to start of learning the basics of the widely-acepted "standard" code. Any suggestions?
Unread 06-01-2005, 23:25
Goobergunch Goobergunch is offline
FRC #1168 (Malvern Robotics)
Goobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to all
Re: Programming Code
In 2004, the robots were programmed in C. I doubt that this will change for this year.
Unread 06-01-2005, 23:27
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
If First were to change the language, I think they would have warned us like they did last year.
sburro's Avatar
AKA: Joe
The language on the first robot is c. This is a "scaled down" version of c++. If it is strictly an intrest in First, then C is the way to go. You can not program the controller in any other language.
Unread 06-01-2005, 23:28
if i learned c++ instead... would i still be able to know c? or are they two just way totaly different things? what are the benefits/downsides of c/c++?
Unread 06-01-2005, 23:48
vtrehan's Avatar
vtrehan vtrehan is offline
Mentor - Controls & Programming
AKA: Vivek Trehan
FRC #1241 (Theory6)
vtrehan is on a distinguished road
Send a message via Yahoo to vtrehan
Of course, but i would suggest learning C first, the reasons being:
1. C is easier and simpler to work with.
2. C can be compiled with any compiler, including C++ compilers, whereas C++ can not be compiled in MPLAB, the compiler we are supposed to be using.
3. C is low level programming, meaning we can work directly with register values and do binary programming used widely in engineering type programming, which is what we are supposed to do. But C++ is a high level language mainly used to do programming for businesses.
C is really simple to use and their is a tonne of tutorials present for it, but if you need any specific help, PM me and ill do my best to help you out.
Best wishes
Vivek.
2006-GM Industrial Design Award - Greater Toronto Super Regional
2006-Engineering Inspiration Award - Arizona Regional
2006-Regional Finalist - Arizona Regional
2005-Best Defensive Robot - Wonderland Off-Season
2005-Regional Chairman's Winners - Greater Toronto Regional
2005-Regional Champions - Waterloo (Thanks 68 and 1305)
2005-Best Website - Greater Toronto Regional
2005-Team Spirit Award - Waterloo
2005-Entreprenuership Award - Waterloo
2004-Rookie All-Star award - Great Lakes Regional
2004-Rookie Highest Seed - Greater Toronto Regional
2004-Rookie All-Star award - Greater Toronto Regional
2004-Team Spirit award - Greater Toronto Regional
2004-Team Spirit award - National Championship
Unread 07-01-2005, 11:54
BrianJennings BrianJennings is offline
Sleep is optional
None #1519 (Mechanical Mayhem)
BrianJennings is an unknown quantity at this point
Send a message via AIM to BrianJennings
From my understanding c and c++ are extremly similar. I think the only different between them is some code and added features to c++. So you could think of C++ as C. but ++...(AKA stuff added to it)
"it's googleable " -- the_undefined
Unread 07-01-2005, 12:34
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
WARNING: Even more nerd pendantry
C is not a low level language. It's a high level language, just like C++. C++ just has more abstraction incorporated in it, so it's a higher level language than C, but still. Low level languages are languages like assembler where you're actually working with registers and basic processor instructions full time. If you're defining variables and stuff, it's not really a low level language.
Unread 07-01-2005, 12:59
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
I've always considered C to be sort of an "intermediate" level language. It started out with an awful lot of direct mapping of its features to the hardware on which the program runs. When the native register size of the CPU is a native variable type in the language, I don't think it's a very high level language at all. You're not working with the basic processor instructions themselves, but almost everything you do is directly related to those instructions, and using pointers is essentially right down there in the computer's RAM with little if any abstraction.
Unread 07-01-2005, 13:07
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
3. C is low level programming, meaning we can work directly with register values and do binary programming used widely in engineering type programming, which is what we are supposed to do. But C++ is a high level language mainly used to do programming for businesses...
I'd like to correct a few things here.
1: C isn't "easier" or "simpler" for everyone. It really depends on how you learn, and whatnot. I find C++ to be a lot "easier" and "simpler", and I also find C to be the complete opposite. Like I said, it just depends on how you learn, and also your preferences to boot.
2: Most points made in #2 are correct, except that MPLAB is just an IDE (Integrated [sp?] Developement Eviroment). The compiler we're using is called CBOT. MPLAB just makes the coding easier.
3: C and C++ are both low level. C++ can do pretty much the same thing as C, and plus some (as far as I know). C isn't all that much low-level though. Is C low-level? Pretty much. Is C++? Pretty much. Anything done in C can be done in C++ (as you've said), so to say that C++ is a low-level language is kind of a lie.
If anyone would like to correct me on any points I've said and am wrong, please do so. My apologizes also for going off-topic, but I thought I should clarify some misconceptions that was said in the quoted post.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 06-01-2005, 23:33
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
WARNING: NERD PEDANTRY AHEAD
C is not a scaled down version of C++. C++ is an object oriented version of C, along with a few other differences. You can most certainly program the robot in another language, and in fact the default code does: it's sprinkled with assembler. The Microchip compiler adheres to the C18 standard, which is a stripped down version of C.
While C is definately the best way to go for FIRST, many other compilers have been written for PICS, but C is the second most common language used on PICs in "the real world". Most PIC applications I've seen are done in straight assembler.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
A Centralized Code Dump? colt527 Programming 29 01-01-2005 16:07
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
