Go to Post Maybe this thread should be re-titled "Waiting impatiently for the 2011 hint!" since having over 100 posts doesn't seem very patient. - Joe Ross [more]
  #31   Spotlight this post!
Unread 08-01-2005, 22:39
David Hoff's Avatar
David Hoff David Hoff is offline
FRC #4050 (Biohazard)
David Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to allDavid Hoff is a name known to all
Re: Basic Game Breakdown
Originally Posted by Mike Ounsworth
I appologise for posting needlessly, but I'm having troubles finding info on this new 'fixit window' rule, could someone please enlighten me?
For info about the fix-it window Read R13 on page 10 in Section 5 of the manual.
Cyber Blue Team 234: Indianapolis, IN 2002-2006
Purdue FIRST Programs: West Lafayette, IN 2006 - 2010
Cyber Titans Team 3793: Frederick, MD 2012
Biohazard Team 4050: Chambersburg, PA 2014
  #32   Spotlight this post!
Unread 08-01-2005, 23:21
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
Just a note - there is a ton of rules explanations and clarifications and questions in the "rules/strategies" thread...
But.....
Originally Posted by greencactus3
well in the animation the short robot lifted one wheel to be behind the line, as in no contact with the ground past the line but hanging over the plane, so i would think yes its ok.
Hanging over should be ok.. It says you're not in the endzone if you're touching the field beyond the white line. So if an arm is hanging over the white line, but not touching the field, then that should be ok.
But can you go under or into the goals in the end zone so that all robots fit?.
I don't see why not. Roll over the goal pipe, and you should be ok. I have not seen any clear rule that says you can't drive under, or go under, the goals.
how many bonus points do u get for capping with the vision tetra and knocking off the hanging tetras???.
You don't get bonus points, you get bonus tetras placed on your corner goal(s). You don't get bonus points for knocking off the hanging tetra, it just comes into play much sooner than if you don't knock it off.. (it'll be removed from field if you don't knock off in auto).
But what about the "Robots may not extend under"...does that mean you cannot drive under or you cannot expand your robot under as to lift the goal?.
I believe "under" does not mean you can't drive thru or go inside a goal. I would think extend under is in context with the tipping/lifting of a goal, meaning you can't lift or tip the goal by ripping it's bottom leg from it's velcro secure.
If you couldn't extend under a goal at all, you would have a tough time getting the tetras under the goal, or removing them from under a goal ("contained" in a goal)... which is all legal.. so that's my take..
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
  #33   Spotlight this post!
Unread 08-01-2005, 23:29
Levin571's Avatar
Levin571 Levin571 is offline
DC Regional VC
no team (Former Team Paragon member)
Levin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud of
Send a message via AIM to Levin571
it mentions tipping as a no-no but if nothing is said about lifting, that could make some very interesting robot designs
2012 FIRST DC Volunteer Coordinator
2003-2005 Driver/Operator
2006 Scout
2004 UTC New Englands Winner
Co-Founder of FF
  #34   Spotlight this post!
Unread 08-01-2005, 23:30
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
How will the tetras be distributed in the beginning? I would guess 5 on the field (2 hanging, 2 vision, and 1 robot), then the other 35 be distributed as follows (7 to each team in the alliance (21), and 7 for each manual station (14).) What would happen if one station or human player runs out? Do they take tetras from the "automatic" despenser or what? For example, if an automatic despenser field attendant runs out of tetras, will s/he take tetras from the human players?
  #35   Spotlight this post!
Unread 08-01-2005, 23:35
AmyPrib's Avatar
Michael - this is all answered in the rules/strategy section.
Please read that for tons of information.
40 tetras per color... 4 automatically start on the field.. with the5th possible on the robot if you choose.
Dave Lavery posted in the other thread that they will try to keep the HP and auto load zone quanitites balanced at all times. So they will try not to totally deplete one side, and keep both side flowing.
Levin571 - it does clearly say no lifting.
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
TV Commercial Game - Rules and Regulations Elgin Clock Games/Trivia 6 01-12-2004 19:07
[Official 2005 Game Design] OK, so YOU design the 2005 game... dlavery FRC Game Design 37 26-10-2004 23:15
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
