Go to Post I think this just hit the nail in the head with a sledgehammer. - Yan Wang [more]
Unread 09-01-2005, 11:33
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
Re: Tetra Manipulators
Originally Posted by n0cturnalxb
Or pick the tetra up from the bottom PVCs and hold it tilted at an angle towards the robot. That way, you wouldn't have to get the tetra as high up as the goal, just almost.. and then tilt it away from the robot, lower the tetra however low it must go, and then move away.
right. so if you get a small (Well doesnt have to be small) grabber that will grip one side of the tetra tightly enough so it wont slip or spin, then you can use a 4 bar or anything w/e to lift it vertically .. and then have a bit of or wait a second... since the sides of these tetas are uhhh 60 degrees?or a bit less i think... since its not a pyramid. dont feel like looking up geometry dimensions now.. well anyways,,, if you get a grab on this at one side from a 120?60?(where am i measuring from?) angle,
like
.............o.......
.......a..//...arm
.b.--------.c
...tetra
(o is the arm axis)
and then rotate the arm up so itll look like
.......b
.c.--------.a
.................o
then you will have a 'holding as if it were flat on the ground" even though the
arm has rotated.. makeing full use of the tetrahedral shape... little problem with the vision ones tho im thinkin..
Last edited by greencactus3 : 09-01-2005 at 16:43. Reason: right triangles have 60 degree insides not 120
Unread 09-01-2005, 23:24
leo_singer's Avatar
leo_singer leo_singer is offline
#1111 (Seahawks)
leo_singer is an unknown quantity at this point
Originally Posted by greencactus3
so if you get a small grabber that will grip one side of the tetra tightly enough so it wont slip or spin
Exactly how tight is that? Maybe it might be easier to handle a tetra if you grab it from a vertex, or from two edges.
But I do like the idea of taking advantage of the tetrahedron's rotational symmetry.
Unread 09-01-2005, 23:35
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Well, looking at one of the posts, I noticed this: "And one other thing about the tetras that may or may not be addressedsoon...holding some of them, a loose nut in one piece of the pipe will cause that part to spin around. Know that if you're planning on building a one-pole grabber." This could be another problem similar to somwhat deflated blass and deformed balls at competition in '04. It wouldn't surprise me if this was considered part of the challenge. If in fact though the edges can spin, then any height advantage gained by grabbing an edge would be lost. (your arm has to extend to a little less than 9 feet, if you're doing an arm that pivots at the base of the robot)
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 10-01-2005, 12:37
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
Wow, 3 people able to draw their designs using text in a script processor program. I guess I wasted my time learning all that CAD software
I've got an idea for a grabber Ty - you may recognize it from Fluffy.
Close enough to taste it, too far to reach it
Unread 10-01-2005, 12:58
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Rookie Year: 1999
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
The tetras are glued together and the bolts in them have loctite. This should not be a problem.
Wetzel
Unread 10-01-2005, 18:53
occra 23.
AKA: ryo
None #1481
well thats where you have to fing the best gripping material against the pvc. spongy rubber most likely, im thinking maybe bicycle brakes. but we dont really want to take forever in aiming it correctly either. or crack a pipe.
I'm not sure I would count on that keeping them from rotating. Regardless of them being glued together and having loctite on the bolts, each leg is an axis that is held by a single bolt at each end along that axis. What keeps the bolt and leg from spinning in the hole in the end connector? I wouldn't rely on friction, and any loctite in that hole won't cut the kind of moment induced from swinging a 9 pound tetra.
you're right. so maybe once someone builds a tetra correctly and rightly abuses it, see what happens. but we still hafta think about the IFs. sooooo.... what now
Unread 15-01-2005, 23:07
Kelvin Ng Kelvin Ng is offline
None #1558 (ACCIDENT Robotics (Albert Campbell Collegiate Institute stuD)
Kelvin Ng is on a distinguished road
me, my father and our team have all brainstormed a whole ton of grabber ideas: first of all, it is our first year and that i'm unfamiliar with alot of terms that you guys might use...a 4-bar? ??? thats an example.
1) pincer - just a pincer with rubberized grips that hold onto one pole.
2) no name - a 2 pronged design that skewers the tetras, then expands (kinda like a pair of doors in an an entrance), eventually expanding to the bottom 2 corners of a tetra and holding them in place by pinning them against a barrier at the back of the grabber. hard to explain.
experiments with straws show that it is possible to skewer the tetras from a wide variety of angles, the tetras are held tight (do not move), and they are held from the bottom, so the arm doesnt have to be as long. my team doesnt like it, but i like it most.
3) 3 pronged grabber (fork) - 2 outer prongs move up and down, central prong remains stationary. central prong skewers tetra apex, the 2 outer prongs lower, making contact with the 2 sides of tetra.
comments?
Unread 09-01-2005, 00:10
RONALDO!!!'s Avatar
RONALDO!!! RONALDO!!! is offline
AKA: they call me tater salad
#1155 (BX Sciborgs)
Team Role: Human Player
RONALDO!!! is an unknown quantity at this point
Originally Posted by Tytus Gerrish
okay, this is personally my biggest concern. Designing an Appendage witch is Gracefully Powerful and proficient in handling the tetrahedrons. From the grabber mechanism to the arm Assembly or tentacle or whatever. What are your thoughts?
well man, from what i can tell the actual construction of an appendage to lift the tetrahedrons, but rather the effect that having such a long endefector, or the power necessary to power a platform or forklift type object for lifting and stacking the tetrahedron will have on the 'bot's center of gravity.
Unread 09-01-2005, 00:25
IA-Howitzer's Avatar
IA-Howitzer IA-Howitzer is offline
Theiss
AKA: Andrew Theiss
FRC #0100 (Woodside High Robotics)
Team Role: Leadership
IA-Howitzer is on a distinguished road
Send a message via AIM to IA-Howitzer
Uhhh, if u make a ski-like design with a pole about 2 ft down, u can keep the tetra from sliding down the pole and the ski-ended part will keep the tetra on and allow it 2 b easily unloaded onto the large stationary tetra.
_______L_____¸,. <---Ski
Unread 09-01-2005, 01:12
Cyberguy34000's Avatar
Cyberguy34000 Cyberguy34000 is offline
Scout-Master
AKA: Chris
FRC #0662 (Rocky Mountain Robotics)
Team Role: Scout
Cyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond repute
Send a message via AIM to Cyberguy34000
Obviously the problem with the arm isn't going to be grabbing the tetras, parsay, but getting them up high enough. It would be pretty sad to get to a match where every robot was only designed to just put one tetra on top. Imagine how much fun that would be for the one robot that could stack higher...
I love deadlines, I love the wooshing sound they make as they fly by. - Douglas Adams
They who would give up an essential liberty for temporary security, deserve neither liberty or security. - Benjamin Franklin
Unread 09-01-2005, 12:12
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Thats what i was thinking. If you don't drive into the large tetra stacks (over the pvc bars and such) your robot will have to reach about 2 feet in to get it over the top of the stack. But after that just lower your arm/forklift/whatchamacallit down and i'm pretty sure the tetra will sort itself into a nice position.
I guess the question is, are other teams going to be knocking tetras from your grasp. Without an actuating grabber your tetras could easily go flying.
Team Website
Unread 09-01-2005, 15:50
Ductapemaster05's Avatar
Ductapemaster05 Ductapemaster05 is offline
I am the Bobcat
AKA: Andrew
#0177 (#177 Bobcats)
Team Role: Mascot
Ductapemaster05 is an unknown quantity at this point
Send a message via AIM to Ductapemaster05
Lightbulb Re: Tetra Manipulators
i thought that it would be a good idea to have an arm the has a 60 or so dergee angle on it so you can hold two of the base sides for a better hold then have it clamp down on the pvc, and lift it up like a fork lift
___ <-- fork lift type structure
|| <- arm
/\ <--tetra, with out the third side
imagine it from looking down at it, also imagine that the arm has about a 60 degree angle on it because if i remember right tetras have 60 degree angles. then have it drive up to it get it with in the arm angles and then with the two grabbers on each end clamp down and use the fork lift mechanism to lift it up and cap the goal
Unread 08-02-2005, 21:23
Bernardo F's Avatar
Bernardo F Bernardo F is offline
Who Am I?
FRC #0968 (RAWC)
Team Role: Student
Bernardo F is on a distinguished road
our team has a grabber that grabs UNDER the APEX of the tetra, can grab three tetras at the same time, then can be put up 12 1/2 feet, then telescoped another four feet.
I think. After that, CG is what we have to worry about.
Unread 08-02-2005, 22:48
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
Wink Re: Tetra Manipulators
Thirty pounds of tetras 12 or 16 feet from the ground (if I read your post correctly), held by an arm that has to weigh 20-40 pounds? Yeah, I'd do the CG calculations if I were you.
But if it falls over really dramatically, can you please post video?
Seriously, I expect to see a lot of robots s-l-o-w-l-y rotating to the ground, losing the CG war. I kind of expect to see some teams driving out from under their top-heavy bots. Let's see, applying a force at ground level underneath a structure 8 or 10 or 12 feet high, with a high polar moment of inertia...
- Rick Tyler
Old Guy with a Sticky Shift KEy
  #15   Spotlight this post!
Unread 09-02-2005, 21:48
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
I think we've struck a good balance with our arm. We've sacrificed being able to stack multiple tetras for speed. We don't shoot up our arm over 12 ft like many are trying, we are shooting for an arm height of 10.5 ft, which is great for our needs. We should (I'll post some video in a few days) be able to stack a tetra that is within 3ft of a goal, per se, onto the goal in (I'd estimate) 5 seconds (tops!)
This assists our strategy, which is focused a little more on the rows themselves, but still leaves the door open for quick loading of several tetras.
Our grabber this year is simple, as I posted above, we're currently just using a pole, probably with a divot cutout for the tetra to sit in (and rest on some digital sensors...)
We're probably just using some sched. 40 PVC, just like the goals. Perhaps aluminum, but I don't think there's really going to be a difference in our design.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Tetra Rods Steel, not PVC? Matt Adams General Forum 13 10-01-2005 05:15
Excel Scoring Spreadsheet cbudrecki Rules/Strategy 10 09-01-2005 18:42
Basic Game Breakdown Levin571 General Forum 34 08-01-2005 23:35
The Game Bharat Nain General Forum 107 08-01-2005 17:07
