Go to Post when all else fails, try making the bot go slower - KenWittlief [more]
Unread 08-01-2005, 20:38
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Drill Motors Removed? Illegal this year?
I am a first time rule reader this year so please bare with me..
I have seen that FIRST elimated (removed) the drill motors from the kit this year, so if there was a transmission design that used a drill motor, it can not be used this year correct?
quoted from kitofparts.pdf:
"Removed 2 Bosch drill motors & transmissions and replaced them with 2 CIM motors with FIRST transmissions."
It doesn't look like any motors the size of drill motors are included in the kit of parts. (I don't know the names of the motors below and what they look like)
Motor, Globe, w/drive assy
12 Vdc
409A587
Motor, CIM
Keyed output shaft
FR801-001
4
Motor, Nippon-Denso, Window , RH
Motor, Sliding Door
Taigene
Motor, Window, Jideco
RH or LH provided
Motor, Fisher-Price, w/21T #7 Gearbox
12 Vdc,, stall torque 532.19 (mNm)
I assume that you must only use these motors when you build your robot?
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
HOT drill motors Rich Wong General Forum 4 29-01-2003 22:38
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
Urgent...Modifying this years drill motors Mimi Brown Motors 17 07-01-2003 23:04
Ordering Extra drill Motors mnkysp6353 Motors 1 30-09-2001 03:21
what about the drill motors? Ken Leung Motors 2 26-06-2001 02:11
