Thread Tools |
Rating:
Display Modes |
One thing to note on the hanging tetras...
I was looking at the field today, especially at the hanging tetras.
I'll tell you now, if you didn't figure it out already (and by looking at the topics thus far, it doesn't look like anyone has)...
Re: One thing to note on the hanging tetras...
another thing to note, though might have been said, is that you can't just through them on top, you have to place them as shown in the clips. I suspect that if you just carelessly put them on top, they might not align easily. i hope that made sense, it's real early right now, i'm going to prepare our bot for the israeli kickoff (which will be really boring cause i watched the whole thing yesterday ) |
Of course, you can retighten it (I fixed one with my fingers), but when you've got 80 of the darn things around the field, that may get a bit unwieldly. |
I don't know about giving it a side whack would take it down. They are using some pretty heavy magnets (50 pounders to be exact). That'll be a little bit of force to take down. Nothing that should be too hard however.
Well..the tetras would in no way be able to be held up by 3 lb magnets as they are 8.5 pounds each. I was talking to one of the builders of the field in Kokomo. I asked how the hanging tetras were attached. He said there are 3 washers on the tetras and a 50 lb magnet on the goal.
the magnets are small round disc-shaped magnets that can rotate 360 degrees It doesn't take much force to knock the tetra down
I personally think 30 would sound like a better number. 50 seems like it would be an overkill.
#11
Thanks Joe - I missed that.
The hanging tetras weigh about 8.5 lbs (vision tetras weigh more) so - I suppose that makes sense. Hope it is 30 lbs. although impacts tend to dislodge magnets even if they are pretty strong. |
#12
I don't know how much impact they will receive since the hanging tetras will only be available in autonomous mode.
#13
Seems like it'll be quite common for teams unable to get the vision tetras. |
#14
I have looked everywhere and can't find out how many points you recieve for knocking off a hanging tetra or for capping with a vision tetra. Does anyone know???
#15
When all else fails, check the manual.
If you put a vision tetra on a goal, it counts as a normal tetra--three points. (And then there's the whole bonus tetra thing--check the manual for that.) If you knock off a hanging tetra, you get nothing for that--but dropping the tetra into the area under the goal is one point. |
| Rules for hanging, using a loop over the end of the bar | caffel | Rules/Strategy | 10 | 04-06-2004 15:04 |
| hanging | Gamer930 | Rules/Strategy | 7 | 17-01-2004 18:30 |
| 1999....look there for hanging | ggoldman | Technical Discussion | 3 | 14-01-2004 12:50 |
| hanging off off other robots that are hanging off the horiz bar | Andrew Dahl | Rules/Strategy | 15 | 12-01-2004 19:14 |
| Starting position and hanging clarification | Don Wright | Rules/Strategy | 2 | 10-01-2004 14:21 |
