Go to Post One of these years, the game piece will be an actual red herring. - Taylor [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 08-01-2005, 23:06
squeeks548 squeeks548 is offline
Sean Bodrie Robostangs #548
#0548 (Robostangs)
Team Role: Mechanical
squeeks548 is on a distinguished road
Angry Inventor problem! Dimension Error
Just a question, I think that I messed up a setting but maybe not because it never worked. When I draw something in sketch mode and go to dimension wherever i place it it cuts the drawing off to the right of it. I'm confused. I am going to re-install once i get the program back from a friend but that might be a while. Anything helps. Sean
Unread 09-01-2005, 19:57
rmmlg's Avatar
rmmlg rmmlg is offline
#0900 (Infinity)
rmmlg is on a distinguished road
Re: Inventor problem! Dimension Error
You mean, all lines, shapes, whatever you had drawn to the right of where you placed the dimension simply disappear when you place the dimension. I'm not quite sure what you are saying. If I am wrong, please clarify.
Ryan
Team 900 (Infinity)
Unread 09-01-2005, 20:23
#0548 (Robostangs)
Yes you are right it does not render anything, I talked to one of my friends and he said that also happened to one of his computers and he found no way of fixing it.
Unread 10-01-2005, 17:51
JasJ002's Avatar
JasJ002 JasJ002 is offline
Inventor Freak
AKA: Jay
FRC #0662 (Cybersonics)
JasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the rough
Send a message via AIM to JasJ002
Talking Re: Inventor problem! Dimension Error
Maybe you could add a visual so that we would further know what you were talking about.
Unread 10-01-2005, 18:55
Karthik1's Avatar
Karthik1 Karthik1 is offline
830 Alumni
AKA: Karthik Chokkaram
FRC #1504 (Desperate Penguins)
Karthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to all
Ya this happened to my inventor to, I can't find a solution.
I made a thread about this a while ago:http://www.chiefdelphi.com/forums/sh...ad.php?t=31928
If anyone knows of a solution please give.
"freedom is voluntary self control” Mahatma Gandhi
Unread 10-01-2005, 19:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I'm still guessing that it is either a graphics card, or graphics card driver incompatibility issue.
Unread 10-01-2005, 19:18
Karthik1's Avatar
830 Alumni
No it can't be that, because I used inventor for two or more months before this happened. I never changed my graphics card.
Unread 10-01-2005, 22:34
#0548 (Robostangs)
Yea I have no idea what is going on i un-installed and re-loaded and it still does the same thing. Inventor 6 worked and now 7 does this so i have a few choices, go back to 6, or go to 8 or 9. The only problem with going up is that when i try to bring it from my computer is that it might not work with version 6 that is at school. This is why i am leaning with just going back to 6. thanks for all of the help. One of my mentors said it might be memory or harddrive space but with 1 gig of memory and 40 of harddrive space i don't think so. oh and i went to the autodesk and is says that the graphics card and driver will work so that eliminates that.
sean
Unread 11-01-2005, 07:32
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Have you gone to the Autodesk site for help? See this...
http://usa.autodesk.com/adsk/servlet...linkID=4183228
Are you running 98 SE like this suggests.
Al
WB9UVJ
www.wildstang.org
________________________
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
Error in Visual C++ Ashley Weed Programming 15 06-05-2004 14:53
Strange 16 bit MS-DOS subsystem error Crazy_Ed Programming 6 18-03-2004 14:31
strange error Anthony Kesich Programming 2 25-02-2004 18:55
EMERGENCY! EPROM FULL error?!? CHSguard72 Programming 2 05-03-2003 20:51
