Re: Electromagnets to pick up tetra?
I'm guessing they wont allow it because it's accidental damage waiting to happen... |
The main thing adding weight to the tetras are the steel brackets at the corners. I was lucky enough to be assembling pieces at a remote kickoff.
Actually, an electromagnet probably wouldn't adversly affect the robot controller. The controller is designed entirely using solid state devices (no magnetic storage), so it should be immune to any magnetic field that could be generated by a FIRST robot.
I'm pretty sure Dan is correct... An electromagnet wouldn't hurt the controller... think about all your motors... CIM's in particular... they generate a HUGE EMF field (we were messing about with a compass one year and they messed it up)... but they dont hurt the controller, even when placed side by side. I'm pretty sure magnets are harmless to the controller.
Per the 2005 Part Use Flow Chart, from page 14 of Section 5 The Robot, electromagnets are not allowed.
even if the magnets are completely harmless, the only metal on the tetras are the bolts. an electro magnet would use power, and a regular magnet would present the problem of getting stuck to other robots. there is definitely a possibility of a megnet being used (if legal), but just make sure you design the mechanism good
I think an electromagnet on the arm may be able to be pulled off(providing its legal) but its just not practical.
There shouldnt be anything in the robot controller that could be dammaged by a magnet. The data in the controller is stored in an EEPROM which you have to access through a serial connection in order to erase. Thats what I think at least. What I know is that they designed the field with magnets in it, and plus, I have personally run a chiwopuha motor (electromagnets make motors go) on top of a robot controller just to make sure nothing happens, and it doesnt.
In any event:
whilst they wont pick up the tetras, they could be useful in that you could hold the tetra in teh game by using an electromagnet to close a grip, but also when you turn the power off, the electromagnets will also go off and iwll fullfill the part of the rules for "you must be able to remove a tetra from
a robot which is deactivated" |
#11
"Per the 2005 Part Use Flow Chart, from page 14 of Section 5 The Robot, electromagnets are not allowed."
the further discussion of this topic is futile. Last edited by Anchi : 10-01-2005 at 07:32. |
#12
| How does your team pick presidents/ captains? | Marygrace | General Forum | 30 | 29-04-2003 22:37 |
| Top seeds pick.... | archiver | 2001 | 6 | 23-06-2002 23:12 |
| When does FIRST pick the game? | archiver | 2000 | 9 | 23-06-2002 22:08 |
| Sponsers: Whats the best way to pick THEM up? | Wetzel | Chit-Chat | 2 | 06-05-2002 22:32 |
| How many balls can you pick up?????????? | CMC | General Forum | 6 | 14-02-2002 21:40 |
