Go to Post I'm really impressed with how much effort we'll go to, to avoid buying a $25 servo tester. - MrForbes [more]
Unread 09-01-2005, 02:15
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Restricted to the Anderson Connectors in the Kit?
My take on rule <R48> is that we are not allowed to use battery connectors other than provided in the kit. Why is this? In the past we have been able to use different (better) powerpole model conectors. The ones in the kit are only rated for 50 amps and we can pull way more than that through the breaker and we have seen these things melt/weld themselves together especially after they get scratched by using the aligator clips on the chargers. Why "must" we use these? Also, the 6 gauge wire on them is not very good.
need standard kit gearbox Korbin Kit & Additional Hardware 0 15-11-2004 21:18
PWM Style .100 pitch Male Connectors BrianBSL Electrical 2 05-10-2004 19:43
Q&A Discuss: How many Van door motor(s) come with the kit? CD47-Bot Extra Discussion 1 08-01-2003 11:07
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
