Hall Effect Sensor.
The 2005 kit came with something a Hall Effect Sensor, after a bit of looking I found the manual for it, it's actually a ATS665LSG made by Allegro Microsystems. Allegro desribes it as a True Zero Speed, High Accuracy, Gear Tooth Sensor. What does that mean? Is this the "gyro" for this year? And does this work in congunction with the accelerometer. There are two of Hall Effect sensors so it seems we need to use them in twos. Also the Allegro manual mentions gears and gear tooth length. So I'm a bit confused and a bit curious and maybe even a bit excited. Anybody know anything about the Hall effect?
Re: Hall Effect Sensor.
My GUESS is that you would use these to count gear teeth - used for feedback to determine how fast/far your robot moves, or for sensing the motion of anything else using chain/sprocket. However ours were missing when we did our kit inventory ...
http://www.allegromicro.com/datafile/0660.pdf
I can confirm that is the proper spec sheet for the hall effect gear tooth sensor that is included in the 2005 FRC KOP. It is labled Data sheet 27627.107 |
Arghhh! I don't understand lol.
Ok the Hall Effect sensor counts teeth and has to be mounted very close to the gear. The accelerometer measures acceleration. How is that done and where does it have to be mounted. How do all these values come together in the RC and help me? What does the code that we get for both these sensors do? |
What kind of value does it give out? |
#10
Has anyone had any luck with mounting the hall effect sensors?
i haven't found anything that fits them....... also, if you haven't read the manual it states that you must connect pin 4 to pin 3 externally. -Leav |
#11
From another post, connect to controller using a PWM cable - RED to Pin1 - WHT to Pin2 - BLK to Pins 3 & 4 We will wire, test, then epoxy them into these homemade housings. Mouser PNs 571-14454211 (x2) and 571-16041961 (x4) Good Luck, Jim |
#12
Hey, Stu, it's Christine. I did some calculations.
Wheel radius = 4", Robot speed = 10 ft/sec, gear by sensor has 45 teeth 2 * pi * 4" / revolution * 1 revolution / 45 teeth * 1 sec / 120 " * 1000 mSec / sec = 4.65 mSec / tooth In other words, you can't do this by polling the sensors in a 26 mSec cycle, and you probably can't do it in the fast cycle either. I think the right way to do this is to hook the sensors to a digital counter and poll the counter. I could be wrong. I don't know squat about counters, it's after midnight, and I can't remember how quickly the fast code cycles. I won't be there this weekend. See you all Monday. |
#13
You can get very similar Hall effect sensors from Newark (they are actually just the next version newer, ATS665LSGTN) for $5. So, teams shouldn't limit themselves to just the two in the kit if they want more. There were 762 in stock when I posted this.
#14
This is not a gyro. A gyro returns your angular acceleration (NOT your angular heading... you would need to integrate the acceleration to get that) |
#15
| Making a Sensor Board | SpaceOsc | Technical Discussion | 11 | 15-05-2004 12:46 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Banner Sensor Programming Problem | 2Crisis | Programming | 4 | 24-02-2004 13:40 |
| IR sensor trouble | D.Viddy | Electrical | 2 | 30-01-2004 09:49 |
| Quick Optical Sensor Question | zorro | Technical Discussion | 10 | 21-01-2003 06:39 |
