Go to Post I NEVER doubt the insanity of pig farmers. - Amanda Morrison [more]
Unread 09-01-2005, 15:43
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Re: Hall Effect Sensor.
Originally Posted by Nixterrimus
Alright so this isn't a gyro, I'm good with that, but is this what was Demoed at the kickoff where the robot was able to correct its position? Does the hall effect sensor return your angular heading?
I BELIEVE what was demoed at the kickoff (not 110% sure) was the accelerometer. An accelerometer gives back a reading that tells how fast you are accelerating, i.e. changing speed, in a given direction. Using some programming, you can sense when you are moving and take steps to remedy it. A hall-effect sensor uses a magnetic field to detect a metallic presence, and therefore does not return angular headings. I am pretty sure they put out pulses when a metallic presence is detected. It's just an FET, in other words.
Sparks
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 09-01-2005, 16:02
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
To clear things up, the HAL effect sensors have NOTHING TO DO WITH ACCELERATION, OR HEADING. They are a type of sensor that detects the presence of ferrous materias. They are designed to be mounted up against(but not touching) the teeth of a gear in a gearbox or other assembly. They will output 1 pulse for each gear tooth that goes by them. If for example you were to connect them to your drivetrain, you could count the number of pulses they output to figure out how far your robot had traveled. It is also possible to use them to determine the speed at which your robot (or some subassembly) is moving.
1139 Alumni
Unread 09-01-2005, 17:42
Nixterrimus Nixterrimus is offline
AKA: N. Rowe
#0578 (Blue Lightning)
Nixterrimus is on a distinguished road
Send a message via AIM to Nixterrimus
So this is how FIRST is killing dead reckoning? Hooking these up next to gears tell you how far you've gone, the accelerometer could tell you if you were straight and now we can drive the robot any direction and know exactly how far. Right?
Unread 09-01-2005, 18:01
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
No. To be honest it's still dead reackoning and you still do not percisely know where the robot is with 100% certainty.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 09-01-2005, 18:33
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
Here are a few tips on the Hall Effect sensors:
These guys simply output a digital signal corresponding to whether or not a gear tooth is in front of them or not, and the polarity of the signal depends on the direction of gear rotation wrt the sensor itself (see the data sheet for more details: http://www.allegromicro.com/datafile/0660.pdf). Think of this device as a one-bit wheel encoder when you program for it.
The air gap, according to the manufacturer, should be 0.5-2.5mm, though they assure us that their adaptive sensing technology can make it work for an even bigger gap, especially with larger gear teeth.
The device has an open-drain output stage, but the digital inputs on the RC have pull-up resistors built-in, so you can directly connect the signal to the RC's inputs. Try to avoid grounding the signal wire, though, as this would technically be a short-circuit. Don't worry if you do -- the manufacturer says it has short-circuit protection on the output stage.
Unread 12-01-2005, 11:39
cdawzrd's Avatar
cdawzrd cdawzrd is offline
Vice-President of Caffine
AKA: Jonathan
#0619 (CA Robotics)
cdawzrd will become famous soon enough
Send a message via AIM to cdawzrd
So... They are sprocket-tooth encoders. Check.
How do we wire them? They have 4 pins, I haven't checked but it seems like they might fit on a PWM cable, but that only has 3 pins, so is it possible to wire it with only 3 pins or do we need to make new cables?
--Jonathan
Unread 12-01-2005, 16:21
scottm87 scottm87 is offline
AKA: Scott McClure
#0469 (Las Guerrillas)
Rookie Year: 2000
scottm87 is on a distinguished road
--Jonathan
To wire this sensor, I suggest you check out the spec sheet that is linked numerous times in this thread. A link to the sheet is on the FIRST site at:
http://www2.usfirst.org/2005comp/Specs/gths1.pdf
For a basic overview, looking from the top of the sensor, the pins from left to right are supply, output, int. connection, and ground. it can take 4.5 to 24 volts input voltage (you would probably use 12), and the output will provide a digital signal whenever a gear tooth passes by (whether or not the output is high or low when a tooth goes by depends on the direction of rotation).
CHECK the spec sheet before you try it. It is helpful to see the diagram and check for yourself.
Scott
Unread 17-01-2005, 19:16
Derder1625 Derder1625 is offline
Derder1625 is an unknown quantity at this point
[font=Comic Sans MS][font=Comic Sans MS]hm.. so afterall that has been said..
does anyone know where could we find the manual
for the hall effect sensor??~
thank yoU~~
Unread 17-01-2005, 19:22
=] May someone please tell me
of the hall effect sensor?? =] thank you
Unread 17-01-2005, 19:42
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Please read this thread. The data sheet link is given.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 09-01-2005, 12:57
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Originally Posted by scottm87
This is not a gyro. A gyro returns your angular acceleration (NOT your angular heading... you would need to integrate the acceleration to get that)
Gyros measure angular velocity, not acceleration. The first integral of the velocity it the distance, so integrating a gyro provides angular distance, or relative heading.
Using a gyro to measure the robot's heading is pretty common with FIRST robots. The parts teams used last year are the Analog Devices ADXRS150EB and ADXRS300EB. The only difference is that the 150 can measure +- 150 degrees per second and the 300 measures up to 300 degrees per second.
Lots of posts describing how to do it.
Unread 12-01-2005, 16:32
AKA: Scott McClure
Rookie Year: 2000
Oops! You are right... With all the accelerometer discussion, I got all mixed up. The ADXRS sensors are nice, but you need to deal with the packaging. I think (not sure) the price limitations have been loosened enough that you can get an evaluation version of the accelerometer with some support circuitry brought out header pins that can be plugged into a board. This is much easier than dealing with a surface mount part, if you do decide to use it. Since there are more suppliers, it may also be possible to pick up other sensors now (the Memsic ones are also nice... and if it is allowed, you can buy it from Parallax pretty cheap.) Heh, you may even be able to get the old FIRST accelerometers from some supplier.
Unread 09-01-2005, 12:34
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Nixterrimus, Is Ken Wittlief still on your team? He should be able to explain the sensors and demonstrate their usage.
Unread 09-01-2005, 12:40
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
This is a neat article I found on calculating heading with a rate gyro.
http://www.seattlerobotics.org/encod...onal_gyro.html
Not sure if FIRST provides us with this code though, I'll have to dig deeper into the documentation and report back.
[EDIT] I found this article from a Hall Effect sensor manufacturer about how they work. http://www.micronas.com/products/ove...sors/index.php [/DIT]
  #15   Spotlight this post!
Unread 09-01-2005, 12:45
AKA: N. Rowe
I looked at that too. Did you think that it was in English?
I thought that a lot of it was out there, I suppose I'm looking for just an intro to the hall effect.
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
IR sensor trouble D.Viddy Electrical 2 30-01-2004 09:49
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
