Go to Post At this point in build season, I'm thinking that whatever type we can get built and working is the best type, by far! - MrForbes [more]
Unread 09-01-2005, 11:39
Nixterrimus Nixterrimus is offline
AKA: N. Rowe
#0578 (Blue Lightning)
Nixterrimus is on a distinguished road
Send a message via AIM to Nixterrimus
Hall Effect Sensor.
The 2005 kit came with something a Hall Effect Sensor, after a bit of looking I found the manual for it, it's actually a ATS665LSG made by Allegro Microsystems. Allegro desribes it as a True Zero Speed, High Accuracy, Gear Tooth Sensor. What does that mean? Is this the "gyro" for this year? And does this work in congunction with the accelerometer. There are two of Hall Effect sensors so it seems we need to use them in twos. Also the Allegro manual mentions gears and gear tooth length. So I'm a bit confused and a bit curious and maybe even a bit excited. Anybody know anything about the Hall effect?
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
IR sensor trouble D.Viddy Electrical 2 30-01-2004 09:49
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
