Go to Post Jon is very right, going forward I have a hard time envisioning any future Championship Chairman's award winners without a significant social media presence. It's just too big of an avenue to be ignored. - Karthik [more]
Unread 09-01-2005, 11:39
Nixterrimus Nixterrimus is offline
AKA: N. Rowe
#0578 (Blue Lightning)
Nixterrimus is on a distinguished road
Send a message via AIM to Nixterrimus
Hall Effect Sensor.
The 2005 kit came with something a Hall Effect Sensor, after a bit of looking I found the manual for it, it's actually a ATS665LSG made by Allegro Microsystems. Allegro desribes it as a True Zero Speed, High Accuracy, Gear Tooth Sensor. What does that mean? Is this the "gyro" for this year? And does this work in congunction with the accelerometer. There are two of Hall Effect sensors so it seems we need to use them in twos. Also the Allegro manual mentions gears and gear tooth length. So I'm a bit confused and a bit curious and maybe even a bit excited. Anybody know anything about the Hall effect?
Unread 09-01-2005, 11:48
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Re: Hall Effect Sensor.
My GUESS is that you would use these to count gear teeth - used for feedback to determine how fast/far your robot moves, or for sensing the motion of anything else using chain/sprocket. However ours were missing when we did our kit inventory ...
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 09-01-2005, 12:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Check the Accelerometer bag. They are very tiny things and many teams have found them stuck to the accelerometer so they look like part of it.
Unread 10-01-2005, 09:47
Stu Bloom's Avatar
Thanks, I haven't had a chance to re-check our kit yet, but I see that this is documented in the "Guidelines, Tips and Good Practices" document (page 26 - see attachment). IMO this should have been documented on the kit checklist (to look on the accelerometer). Seems these could be easily missed, even for those who know what they are looking for
Stuart Bloom
Mechanical Engineer
Unread 10-01-2005, 12:21
dez250 dez250 is offline
54... What a good number!
Rookie Year: 2000
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
http://www.allegromicro.com/datafile/0660.pdf
I can confirm that is the proper spec sheet for the hall effect gear tooth sensor that is included in the 2005 FRC KOP. It is labled Data sheet 27627.107
-Michael Dessingue
Unread 10-01-2005, 20:07
Nucks Nucks is offline
'Nucks
#1347 (Trobotics)
Nucks is an unknown quantity at this point
We thought we didn't have it either, but after reading that, we checked and found it, thanks
Unread 10-01-2005, 20:37
xxmaddjxx's Avatar
xxmaddjxx xxmaddjxx is offline
Captain & Driver
AKA: Mark Fisher
#1396 (Pyrobots)
Team Role: Driver
xxmaddjxx is on a distinguished road
Arghhh! I don't understand lol.
Ok the Hall Effect sensor counts teeth and has to be mounted very close to the gear.
The accelerometer measures acceleration. How is that done and where does it have to be mounted.
How do all these values come together in the RC and help me?
What does the code that we get for both these sensors do?
"The One Day Wonder"
2004 - Nationals Judges Award
2004 - NYC Regional Rookie Allstar
2004 - NYC Regional Semi-Finalist
Unread 11-01-2005, 07:24
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
If you know what your final gear ratio is (or you test to find out the correlation between counts and inches moved on the floor) you can determine how far the robot has moved. If it runs straight, you can tell where it is at any moment by keeping track of the counts. If you use the accelerometer, you can tell how much the robot has turned (or if it has turned the amount you want it to) so you now have direction and distance. Combine the two and get a rough idea where you are on the field. Be careful, the accelerometer output is proportional to the acceleration in one direction or the opposite direction. If it is mounted parallel to your direction of travel, it has no output. Read the spec sheet carefully to learn all of the nuances of the device and how to best filter out the info you need.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 12-01-2005, 17:17
xxmaddjxx's Avatar
Captain & Driver
AKA: Mark Fisher
#1396 (Pyrobots)
Team Role: Driver
How do you use the accelerometer to know how much you turned and in what direction?
What kind of value does it give out?
Unread 13-01-2005, 14:29
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Has anyone had any luck with mounting the hall effect sensors?
i haven't found anything that fits them.......
also, if you haven't read the manual it states that you must connect pin 4 to pin 3 externally.
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 28-01-2005, 10:56
jimsmith2354 jimsmith2354 is offline
FRC #0279 (Tech Fusion)
Rookie Year: 1999
jimsmith2354 is on a distinguished road
-Leav
Mounting of the Hall Effect sensors - We have drilled out the inside of two small connector housings, sanded off the middle ring on the outside, and will use jam nuts to hold them onto brackets placed near either the output gear or a tone wheel.
From another post, connect to controller using a PWM cable - RED to Pin1 - WHT to Pin2 - BLK to Pins 3 & 4
We will wire, test, then epoxy them into these homemade housings.
Mouser PNs 571-14454211 (x2) and 571-16041961 (x4)
Good Luck,
Jim
Unread 29-01-2005, 00:24
MyFeetHurt MyFeetHurt is offline
AKA: Christine Laing
#1018 (RoboDevils)
MyFeetHurt is an unknown quantity at this point
Hey, Stu, it's Christine. I did some calculations.
Wheel radius = 4", Robot speed = 10 ft/sec, gear by sensor has 45 teeth
2 * pi * 4" / revolution
* 1 revolution / 45 teeth
* 1 sec / 120 "
* 1000 mSec / sec
= 4.65 mSec / tooth
In other words, you can't do this by polling the sensors in a 26 mSec cycle, and you probably can't do it in the fast cycle either.
I think the right way to do this is to hook the sensors to a digital counter and poll the counter. I could be wrong. I don't know squat about counters, it's after midnight, and I can't remember how quickly the fast code cycles.
I won't be there this weekend. See you all Monday.
Unread 29-01-2005, 10:48
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
You can get very similar Hall effect sensors from Newark (they are actually just the next version newer, ATS665LSGTN) for $5. So, teams shouldn't limit themselves to just the two in the kit if they want more. There were 762 in stock when I posted this.
Unread 09-01-2005, 11:50
scottm87 scottm87 is offline
AKA: Scott McClure
#0469 (Las Guerrillas)
Rookie Year: 2000
scottm87 is on a distinguished road
Okay. A gear-tooth sensor sits in your gearbox and uses a magnetic field in order to sense each specific tooth go by. The Hall Effect is the concept that allows the integrated circuit to take a measurement of the magnetic field surrounding it. (Hall effect compasses are also popular) The amount of time that elapses between the each tooth gives the speed of the rotating gear, which can then be scaled to the speed of the wheel, etc.
This is not a gyro. A gyro returns your angular acceleration (NOT your angular heading... you would need to integrate the acceleration to get that)
  #15   Spotlight this post!
Unread 09-01-2005, 12:43
AKA: N. Rowe
Alright so this isn't a gyro, I'm good with that, but is this what was Demoed at the kickoff where the robot was able to correct its position? Does the hall effect sensor return your angular heading?
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
IR sensor trouble D.Viddy Electrical 2 30-01-2004 09:49
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
