Re: 2005 FP Pinion
Joe J. |
Re: 2005 FP Pinion
Read the Friday Email about the Typo in the kit for the FP's. I also had the kids measure the free speed with the transmission. 144 rpm, battery fully charged, fuse, no victor. which is no surprise as last years was 130 same conditions. Cheers Tom Cooper 1227 |
Re: 2005 FP Pinion
Here are a couple measurements on our 2005 Fisher Price Motor
13 teeth; 1/2" O.D. pinion Part ID# 74550-0642 Code: TD034701 Measured RPM*: 24,500 @ ~12V (voltage approx) 12,000RPM @ 6.0V -11,600RPM @ -6.0V (reverse direction) * Measured using R/C airplane hobby tach & transparent disc w/stripe Motor Resistance**: 0.069 - 0.074 ohms **Measured with 10A current source; 4 point measurement of 0.69-0.74 V while turning rotor between fingers Calculated stall current from above: 162 - 173A (12V/0.069ohms; 12V/0.074ohms) All these measurements agree well enough by those provided by Paul Copiola at http://www.chiefdelphi.com/forums/sh...ad.php?t=32442 -David |
Re: 2005 FP Pinion
We've got another pair of
74550-0642 TD034701 13 tooth pinion Haven't measured resistance. We really need to get this cleared up soon because we've all got to buy some gears and sprockets and we need the correct torque/power/speed data... |
To take this question to the next level;
Does anyone know or want to hazard a gues as to what the pressure angle is on the gears used in the FP transmission? Matt B |
Re: 2005 FP Pinion
Re: 2005 FP Pinion
They typically use standard DP and pretty standard gears (no enlargements or thickening of teeth, etc.). Joe J. |
Re: 2005 FP Pinion
So is this 32 DP like the others?
Re: 2005 FP Pinion
13 T, 32 P, 20° PA |
| **FIRST EMAIL**/Important 2005 Competition Manual Information | Sscamatt | FIRST E-Mail Blast Archive | 1 | 06-01-2005 18:50 |
| rack and pinion. | greencactus3 | Pneumatics | 17 | 04-11-2004 23:24 |
| [Official 2005 Game Design] OK, so YOU design the 2005 game... | dlavery | FRC Game Design | 37 | 26-10-2004 23:15 |
| Your Thoughts on the 2005 Championship Eligibility Criteria! | dez250 | Championship Event | 57 | 10-09-2004 14:59 |
| Converting the Bosch Metric Pinion into an English- Specification Pinion | evolution | Motors | 3 | 28-08-2004 16:30 |
