CMUCam2 Vision Sensor Testing/Problems
Hi,
Got camera connected to RC correctly. Performed quick check referring to CMUcam2_fe manual.pdf using HyperTerminal. Instead of getting the correct response on the terminal "CMUcam2 v1.0 c6" I got just a "C:" response. I then loaded "FRC_CMUCam2.hex" into RC. Repeated above and got correct response (c7 instead of c6). I have noted that my RC Mode is blinking red (disabled) and that the program state is solid yellow/red (looks orange to me). Tried running the stand_alone JAVE app to test vision system but I have version 1.3. So, I have just downloaded Java Virtual Machine 1.4 and hope to get it installed soon so I can actually see something on my computer. That'll be cool. Any idea on the RC fault lights after loading the above HEX file? The default code this year loads okay. Noticed Kevin's Navigation program gave me similar faults. Regards, Chuck |
Re: CMUCam2 Vision Sensor Testing/Problems
Just a small update. Installed Java VM 1.4.2_06. I still have the solid orange light for "Program State". The CMUcam2 GUI displays the message "Looking for Camera...".
I just need to sort out the RC program state and I am sure this will work. Regards, ChuckB |
Im having troubles as well.
Does the camera need to be hooked up to the RC in order to work? Right now I have the power of the camera connected to the EDUbot and the serial post is connected to my computer. The CMUCam2 software cannot find the camera, and I tried opening the port using the default settings in the manual. I am able to send commands to the board, but i get no response. I know my serial port is functioning correctly because I am able to send and recieve commands from the edubot controller? Any ideas?! |
I don't know what's wrong really, but the electronics team is having some sort of problem with the camera. I think they want to get a new one.
Hi,
You need to do these things (our experience). 1. Get the frc camera code loaded into new RC. 2. Connect PWM cable between PWM output and power connection on camera card. 3. Connect PWM cable between TTL-RS232 card and the camera card. 4. Power up the RC. 5. Press the Robot Reset button on the OI. Only power on LED is illuminated. We moved a 'red' hat in the view out to 12 feet to make the RED LED come on. Still experimenting... Regards, ChuckB |
[RESOLVED] CMUCam2 Vision Sensor Testing/Problems
Hi,
We can see an image using the GUI software. The only connections to the camera unit are the PWM cable from the PWM output to the camera module and the RS-232 from COMM1 on the PC to the camera unit. Whew! Regards, ChuckB |
I've had a LOT of problems getting the GUI to work correctly. Unless I'm on a REALLY fast computer (my P4 XP unit) the the GUI app won't complete a frame grab. Even the P3/500 was too slow. Anyone else having this problem?
Also, the images look really bad, tinted green, and muted colors. (blue is difficult to identify, and try picking out a green target in a green field!) If I turn the white balance feature on, they look blue. I tried looking at the tracking data, and it had a difficult time following a yellow target on a dark background. I'm really worried about lighting, and how this thing is going to react in the field. Steve |
I got the GUI to work on any computer after fiddling with the serial port stuff for a while, but our images all come out yellow, really yellow, and when we turn white balancing on it looks very nice, but we can't find any colors but green, it syas yellow is too bright, and that red is too dark.... it can't make up its mind, but it tracks the green nicely! |
Steve ![]() |
#10
Follow the manual very carefully. They have everything in there, except you have to SEARCH for it, unfortunately. It has information on what your serial port settings and everything should be. Try taking one more look.
#11
I am also getting the red error light on the OI when loading the test program(s) in FRC_CMUcam2_rev-3. By the way why are there two projects? Which one should we focus on? What does the DDT version do? Why do they causes errors? FIRST you can do better.The camera has potential to give the robot direction. But it is worth the cost? This is turning out to be a bad joke. "Even a blind squirl finds a nut occationally", why not a tetra? |
#12
Matt |
#13
We can't seem to get the camera to track. It seems to get through the calibration OK but when you hit "track" the servos just oscillate and then it sez "Can't track color". The servos work fine manually and are connected properly. Next this is to try and reload the firmware in the cam. Congrats and great job on the progress !! |
| Vision Tetra Alignment accuracy | Rickertsen2 | Rules/Strategy | 10 | 21-01-2005 09:18 |
| Just where are vision "bonus" tetras placed? | David Brinza | Rules/Strategy | 17 | 10-01-2005 20:50 |
| Has anyone ever done any robot vision programming? | Robot Dude 0101 | Programming | 2 | 05-10-2004 13:02 |
| Career Forum - A New Vision | archiver | 2000 | 0 | 24-06-2002 00:01 |
| New Forum - A Vision | archiver | 2000 | 1 | 24-06-2002 00:01 |
