Go to Post FIRST is an opportunity for me to tackle problems that have long been solved. - Madison [more]
Unread 10-01-2005, 14:37
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
extra connector on breaker panel
The new breaker panel has a 3 pin connector next to the LED. It isn't labeled in the manual though. Does anyone know what it does?
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 10-01-2005, 15:44
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: extra connector on breaker panel
There is no documentation, but if I were to guess, (since it is close to the LED) it is likely for remote mounting a monitor, dual color, LED. This is just a guess not a statement!
Al
WB9UVJ
www.wildstang.org
________________________
Unread 10-01-2005, 16:14
Unsung FIRST Hero
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Rookie Year: 1998
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Is this the connector for reporting tripped breakers to the control system?
Matt
Unread 10-01-2005, 16:26
ntroup's Avatar
ntroup ntroup is offline
WildStang!
None #0111 (Wildstang)
ntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud of
From the "Guidelines, Tips & Good Practices" pdf on the 'Documents and Updates' section on the FIRST Site (page 21):
Final note: The PWM socket is not used on this assembly. The DB9 connection can be used to send
CB Panel status information to the RC unit via the Program port connection on the RC.
So, it looks like it is currently un-used.
-Nate
Unread 10-01-2005, 17:15
coreyjon's Avatar
coreyjon coreyjon is offline
Flight Engineer
FRC #0250 (Team 250 Dynamos)
coreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nicecoreyjon is just really nice
Send a message via AIM to coreyjon
Good to know, I was wondering about that myself.
"Jack of all trades, master of none, though offtimes better than master of one".
Unread 11-01-2005, 13:10
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
It would be nice to monitor the breaker during matches, is there a way to do that?
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 11-01-2005, 13:19
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
It's setup to read the breaker status in the default code if the breaker panel is connected to the RC program port.
Code:
if (aBreakerWasTripped)
  for (i=1;i<29;i++)
	if (Breaker_Tripped(i))
	  User_Byte1 = i; /* Update the last breaker tripped on User_Byte1 (to demonstrate the use of a user byte)
	  Normally, you do something else if a breaker got tripped (ex: limit a PWM output) */
Unread 11-01-2005, 13:20
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
It(the PWM port) may not be used with this set up, but could it be used? Could we control the panel or atleast see whats going on durring the match?
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 11-01-2005, 14:41
dez250 dez250 is offline
54... What a good number!
Rookie Year: 2000
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
This is not an offical statement from IFI but i would reccomend highly against connecting anything to that port this season. You do not know the circuitry for that pwm port and since IFI says its not for use this season what i would do is take a lil electrical tape or gaffers tape and cover over that port so by accident it is not used or damaged this year.
-Michael Dessingue
Unread 11-01-2005, 15:57
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
All of that is done via the serial port, not the PWM port. As Mark showed, the user program knows the complete status. That data is also sent to the dashboard, so you can see it real time during a match.
There isn't any reason, that I can think of, to try to figure out what the PWM port is used for, as everything we want is already provided.
Unread 11-01-2005, 20:58
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
If would be nice if the PWM port replicated the function of the LED, so that you could see if any breakers tripped on OI without having to using the serial port on the RC (since you might be using the serial port for something more important like a custom circuit).
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Unread 11-01-2005, 21:15
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
You could always come up with a system to integrate the output from the breaker panal into the digital I/O, or you could use the tether port for the second serial device. Also, there is the TTL port which is ostensibly for the camera, but you can make the camera run on the I/O if you really need to.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 11-01-2005, 22:19
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
Yes you can connect it with a PWM this year. Any status can be viewed through dashboard. Go here for more info http://www.ifirobotics.com/circuit-breaker-panel.shtml, also, make note that the bottom of the page has a bit of information.
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
Digital Breaker Panel Mark McLeod Control System 8 31-01-2005 00:22
Strategies to prevent overcurrent/breaker trip kmcclary Motors 27 28-12-2002 01:00
Keyang Motor Thermal breaker. archiver 2000 1 24-06-2002 00:24
Looking for practice motors & extra tape drive parts? archiver 2000 1 23-06-2002 22:54
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
