Help - new interface, old servos
hey guys and gals. my partner and i have been trying to use the nw interface for the 2005 frc with the old servos from the robovation kit. the servos have a 4 pin connector with black, red, yellow and orange wires. however the new interface had a 3-pin connector with labels for a black, red and yellow/white pins at the relay outputs. the 4th-pin from the servo is the orange wire, which isnt labeled on the interface, and it makes the 4-pin connector from the servo too wide to connect onto the new interface. is there any suggestions? any help is appreciated.
your friend Holy One |
Re: Dilemma!!! Please Help!!!
Off hand, I do not believe that the orange wire is needed . . .
However, if my memory serves, the EDU servos can rotate 360 + n degrees, so I would check the skematic before I pulled stuff off. |
Re: Help - new interface, old servos
ok. another dilemma. we tried to use the new servos, but the old wheels that cam with the robovation kit have a square piece of metal for the axel. the piece of metal is needed for the wheel and in the old servos it went stright into them.
one more thing. i am going to use the extensions that came with the new kit to extend the old servos with a three wire and see what happens. ill see if there is a difference between that and running it with four wires. |
| Serial/Parallel Interface | mchan1111 | Programming | 2 | 22-10-2004 23:36 |
| 2003 robot controller & interface | LGuY | Control System | 3 | 04-04-2004 16:01 |
| how to create custom interface | _GP_ | Technical Discussion | 1 | 18-01-2004 21:24 |
| Looking for operator interface... Where is it? | mike325 | General Forum | 2 | 07-01-2003 15:28 |
| Need help in creating program to use servo's to shift drive | archiver | 2001 | 19 | 24-06-2002 00:35 |
