Go to Post "The robot is horribly overweight. We need to delete some code" - Dumper FTW 435 [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 11-01-2005, 20:47
Jaime65's Avatar
Jaime65 Jaime65 is offline
AKA: Jaime
FRC #3398
Jaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud of
Advice for designing sites with Flash?
HEY DO ANYONE KNOW HOW TO DO A QUICK EASY FLASH WEBSITE OR ANY SUGGESTIONS ON WERE I CAN GO TO FIND OUT
Unread 11-01-2005, 20:49
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: FLASH
www.flashkit.com
it has a lot fo stuff including menu systems small website templates e.t.c. Hope it helps
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 11-01-2005, 21:20
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Re: Advice for designing sites with Flash?
I would definatly check out the site above. In addition, ultra shock (URL ?) has some nice open source stuff. A hint for the beginning Flash artist, actionscript is a lot like C. Also, depending on your application, you may want to ditch swf files, and upload the actionscript as class files (or so my webmaster says).
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 11-01-2005, 21:29
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Someone last year pointed out this site for flash buttons that you can use on your site.
It'll save you a step.
Unread 11-01-2005, 21:34
Goobergunch Goobergunch is offline
FRC #1168 (Malvern Robotics)
Goobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to all
Also, since Flash requires a plugin, you may note that designing most of your site in Flash will lead to your site returning massive blanked/errored spaces for those who haven't downloaded the plugin.
Unread 11-01-2005, 21:36
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
thus you should make a companion html site for those who don't have the plugin.
Unread 11-01-2005, 21:42
CJO's Avatar
CJO CJO is offline
Alternativly, you could only design portions of your site in FLASH out of respect for your webserver
Unread 11-01-2005, 21:47
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
like the intro (with the option to skip) and let the rest be html.
Unread 11-01-2005, 22:13
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
There are many things to keep in mind when using Flash, especially if you intend your site to have a professional "feel" and want to have a lot of users.
First, there is no such thing as too little Flash. None is idea, some is useful, too much is garbage. Don't just use technology because you can. Falling into that trap leads to slow, clunky webpages with dynamic "everythings", annoying the user very quickly. Don't use any dynamic technology unless you have a clear reason for doing so, and particularly Flash. Its too easy to make bad pages that way.
A well-place, professional Flash addition greatly improves the effect of a website. An example of such a thing would be fading borders/mastheads, a menu system, and well-done animations. Cybersonics (Team 103, if memory serves me correctly) had an excellent Flash-based webpage. Flash served an auxiliary role in the layout, assisting the main body of the document, which was classic HTML.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 11-01-2005, 22:15
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
If you want ot see excellent use of flash check out Cybersonics website.
Unread 11-01-2005, 23:58
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
Also, if you use flash for entire pages, don't break the back button. Put each page of information in a seperate flash file (like sites such as HomestarRunner). People are used to how their browser works, and they don't want to have to learn your navigation system.
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Unread 13-01-2005, 10:30
Unsung FIRST Hero
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Flash is not one of my favorite inventions. It has its place, but its place is far smaller than what most people think.
Please don't do something crazy and put a billion different flash elements on your page. If you must have a flash link bar, make the entire bar one flash element and not 8 little ones. If you must have a flash intro make sure you have a 'skip intro' button.
Flash just doesn't float well with me. Heck, I don't even like using images when I don't have to. What can you accomplish with a javascript or flash linkbar that you can't do with XHTML that adds more than a cool fading effect or sounds?
Unread 13-01-2005, 11:36
Roland's Avatar
Roland Roland is offline
Post-A-Holic
#1466
Team Role: Webmaster
Roland is infamous around these partsRoland is infamous around these partsRoland is infamous around these parts
I AGREE WITH MOST OF THE PEOPLE IN THIS THREAD THAT YOU SHOULDN'T DESIGN YOUR ENTIRE SITE IN FLASH. YOU SHOULD BE USING MAINLY HTML FOR MOST THINGS - I MEAN IF YOU DO AN ANIMATION OR SOMETHING IN FLASH THAT'S COOL, AS IS FLASH VIDEO CONTENT AND THINGS LIKE SCALABLE INMAN FLASH REPLACEMENT FOR FANCY HEADLINES, BUT I SUGGEST YOU LEARN HTML AND CSS FIRST BECAUSE AS COOL AS FLASH IS, IT CAN BE A HUGE PAIN TO BROWSE A COMPLETELY FLASH SITE. CHECK OUT W3SCHOOLS.COM FOR A LOT OF USEFUL RESOURCES ON THAT.
ALSO FIX THAT CAPS LOCK KEY
Unread 18-01-2005, 21:50
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
I personally do not like flash.... You can do all of the flash abilities using just HTML and javascript and images, if you would like me to, ill design an html alternative to a flash thing you may want to do...
- from B B frank
  #15   Spotlight this post!
Unread 18-01-2005, 21:55
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Flash is great, but I would only use it on an intro (with a skip button for the 56k users like me). And the plug-in issue: At school some of our computers (the ones that I use) have Firefox and it is hard to download the plug-in and install it at school so the navbar on our website can't be seen. I added a very small links table into the footer of each of our pages so that we could still access everything without opening up IE.
Help with Flash team384_pat Website Design/Showcase 2 11-06-2004 12:36
Why (not) flash? tchescow Website Design/Showcase 10 04-01-2004 16:29
Using Flash Keys Website Design/Showcase 8 12-03-2003 18:31
Flash and IE Raven_Writer Website Design/Showcase 9 09-02-2003 12:26
