Go to Post It is not necessary to draw 200 amps to move a robot through a two minute match. Rule of thumb is you robot should be able to compete for three matches without a battery change. - Al Skierkiewicz [more]
Unread 24-03-2002, 14:56
dkeith dkeith is offline
#0322 (Fire)
dkeith is an unknown quantity at this point
Atwood Motor cutout
I was told and belive that we experenced cutout on our drive system because we were transistioning from forward to reverse too fast with the Atwood motors. Has anyone else experenced this and if so how did you correct it.
Unread 24-03-2002, 15:23
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Rookie Year: 2000
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
That's probably because the circuit breakers are tripping from the increased current necessary to change direction very fast. I think the easiest way to improve it a bit would be a low pass digital filter. More info can be found on Innovation First's website
Manoel Flores da Cunha
Mentor
Brazilian Machine
Team # 383
Unread 24-03-2002, 18:15
thedillybar thedillybar is offline
#0894 (Chargers)
thedillybar is an unknown quantity at this point
Send a message via AIM to thedillybar
We've had some problems with the Atwood motors tripping the 30 amp breakers, but this was only because we were on better carpet than the playing field so we stalled the motors before losing traction. On the playing field we lose traction before the motors stall so it's not a problem.
Unread 24-03-2002, 19:05
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
we had major problems with breakers two weekends ago (SPBLI). then, at NYC we "de-frictionized" the drive train (added lots and lots of ball bearings). the only time we popped any more breakers was when we pushed a powerful robot down the field, and that only happened occasionally.
AIM --> Woloi
Email --> ian@woloschin.com
Where to get CIM (Atwood, Chiaphua) motors? DougHogg Motors 13 16-12-2003 13:21
Chippy (Atwood) output changed Rob Colatutto Motors 2 04-01-2003 21:38
Atwood Powerjack Gearbox Genome17 Technical Discussion 2 31-03-2002 01:02
Is it weird to see an atwood motor floating in mid air? mnkysp6353 Chit-Chat 6 19-02-2002 21:38
question about atwood motor matt sorgenfrei Motors 0 18-01-2002 23:19
