Go to Post If you have not had a positive experience in FIRST, please don't bring those that have down. - Jeff K. [more]
Unread 12-01-2005, 22:50
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
Re: encoders
is that already in the default routine, because our compressor doesn't automatically turn itself on. plus, if you read my above post, are you sure the default settings work with the way my bot is configured? thank you.
Unread 12-01-2005, 23:05
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
Re: encoders
I have some vague recollection that you may not pass inspection if you do not have the pressure limit switch controlling the compressor.
Last year we were overweight and removed our compressor, opting instead to charge the air tanks before each match.
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 13-01-2005, 00:30
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: encoders
Sorry if this is a bit off topic.
I was looking through the encoder the Mr.Kevin provides on his website. I did not find the model of the encoder he was using, i am currently wanting to use optical encoder from digikey there a lot of them available. I am trying to decide which one to buy and will the optical encoder just tick when the dark area changed to light?
Thank you in advance
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 13-01-2005, 01:30
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: encoders
Originally Posted by thoughtful
...I was looking through the encoder the Mr.Kevin provides on his website. I did not find the model of the encoder he was using...
From the readme.txt: "This software was tested with Grayhill 63R256
and 61K128 quadrature output optical encoders. Data sheets for
these devices are included."
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 13-01-2005, 01:35
CJO's Avatar
CJO CJO is offline
Emeritus Pain in the $@#$@#$@#
AKA: Christopher J. O'Connell
None #1097 (Site 3 Engineering)
CJO will become famous soon enoughCJO will become famous soon enough
Re: encoders
As Anthony points out. If you have power to burn, leave the compressor in full auto, if, on the other hand, you want manual control (for any one of a number of reasons) I think that the wheel is a good choice, as it is convienient, and hard to press by accident.
Team 1097 -- Site 3 Engineering
2003 Sacramento Rookie All Star
2003 Silicon Valley Rookie All Star
2004 Sacramento Engineering Inspiration Award
2004 Sacramento Visualization Award
2004 Outstanding Volunteer Award (G. Glasser)
2004 Silicon Valley Sportsmanship Award
2004 National Visualization Runner Up
2004 Cal Games Finalist
2005 Sacramento Sportsmanship Award
2005 Sacramento #1 seed
2005 Sacramento Finalist
2005 Silicon Valley Sportsmanship Award
2005 Silicon Valley #1 Seed
2005 Silicon Valley Finalist
Unread 13-01-2005, 01:16
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Team Role: Leadership
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Re: encoders
I believe it is the pressure blow off valve that cannot be removed, not the pressure sensor. In 2003, we ran without a sensor. That's where CJO got the code from. We used the wheel since we didnt have any more buttons on the controller to map the function to. We controlled it manually since we were having power regulation problems and decided to kill the compressor completely for the last 30-45 seconds of the match.
-Tony K
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 05-02-2005, 13:44
roboticsjenkins's Avatar
roboticsjenkins roboticsjenkins is offline
robotics_jenkins
AKA: Andrew
#0616 (Southampton Indian Robotics)
Team Role: Electrical
roboticsjenkins can only hope to improve
Send a message via AIM to roboticsjenkins Send a message via Yahoo to roboticsjenkins
Re: encoders
How do I hook up th encoders to the RC. I know that they go on Digital I/O, but do I use two PWM CABLES to hook each encoder up or what do I do? Someone please help me.
Unread 05-02-2005, 15:48
Re: encoders
ok, I'm assuming you have a quadrature encoder (this means there are 4 places to hook up wires on the encoder). 1 is the + power pin. 1 is the - (ground) pin. one is the phase -a pin, and one is the phase b pin. this requires two digital ports on the rc. I'm assuming you are using Kevin watson's encoder template (the only way to do this if your a beginner). hook up the +, -, and phase a wires on the digital io 1. then put the phase b wire on digital io (I think, but check the template read me provided b Mr. Watson) on digital io 6. this is how the "left" motor encoder, or w/e our using it for is hooked up.
don't feel too bad, I had this same problem about a month ago, I started a couple threads before I was able to understand it.
hope this helps,
Stephen
Unread 05-02-2005, 16:16
robotics_jenkins
AKA: Andrew
Re: encoders
Let me see if I have this right I have to hook one encoder to two different Digital I/O ports?...I'm so confused
Unread 05-02-2005, 16:25
Re: encoders
ok here it is, and yes, one encoder to two digital IO's. did you read what I said carefully? um, check to see if there are four pins on the encoder, if there are, then you need two digital ios. here-
dig. io 1 ------- phase a pin ------- positive power --------negative power
dig. io 6 ------- phase b pin (only, no power or anything here)
if this doesn't make sense, then you really need to go to the white papers section and read up on interrupts a little and on encoders, and read through the comments on mr. Watson's code. questions are fine, but really, after reading this, you shouldn't be having any problems.
Unread 07-02-2005, 07:24
Re: encoders
(didn't mean to sound mad ) came out that way I guess
Unread 04-02-2005, 23:07
dmurdz's Avatar
dmurdz dmurdz is offline
AKA: Dan
FRC #1027 (Mechatronic Maniacs)
dmurdz is on a distinguished road
Send a message via AIM to dmurdz Send a message via MSN to dmurdz
Re: encoders
Im working on my programming, when it comes to my code I do not know how to set up my interrupt handlers, is there demo code some where for this???
Unread 05-02-2005, 00:11
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: encoders
See http://www.kevin.org/frc/ for lots of example programs, many of which are complete drop-in modules. Scroll down to frc_encoder.zip for interrupt-based encoder code.
Unread 05-02-2005, 10:20
dmurdz's Avatar
AKA: Dan
Re: encoders
Sample code from Kevin on www.kevin.org/frc, the interrupts program, in file interrupts.c, there is a spot that says:
* FUNCTION: Int_3_Handler()
* PURPOSE: If enabled, the interrupt 3 handler is called when the
* interrupt 3/digital input 3 pin changes logic level.
* CALLED FROM: user_routines_fast.c/InterruptHandlerLow()
* PARAMETERS: RB4_State is the current logic level of the
* interrupt 3 pin.
* RETURNS: Nothing
* COMMENTS: The PIC18F8520's RB4/KBI0 pin on port b is mapped to
* interrupt 3 on the EDU-RC and digital input 3 on the
* FRC-RC [108].
void Int_3_Handler(unsigned char RB4_State)
// this function will be called when an interrupt 3 occurs
Is this the final code??? What do I need to add???
HELP!!!!!!!!!!!!!!!!
  #15   Spotlight this post!
Unread 05-02-2005, 12:52
FRC #2429
Re: encoders
It's just template code that shows you how to setup the interrupts. Check out some of the other examples that show you what you can do with interrupts.
-Kevin
Kevin Watson
http://kevin.org
Mechanical Wheel Encoders? Jaine Perotti Electrical 15 04-12-2004 22:46
Shaft Encoders wun Programming 3 12-10-2004 16:40
encoders? what kind and where from? ajlapp Electrical 1 03-02-2004 01:49
Who used wheel encoders CyberWolf_22 Technical Discussion 12 04-05-2003 15:37
