Go to Post Conspire to Inspire despite what may transpire ! - Bill_B [more]
Unread 12-01-2005, 22:08
locohammerhead locohammerhead is offline
locohammerhead is an unknown quantity at this point
Re: If you have questions or comments post here!
I NEED MAJOR HELP ASAP! My team has their minds set on a three wheel desighn and i keep telling them that its not stable and they wont listen and i need as much info about why those are not stable and why a 6 wheel or 4 wheel drive is the way to go. If you could contaCT ME ASAP! That would be great! my email is locohammerhead@hotmail.com just enter that for msn instant messenger aol is locohammerhead and yahoo is locohammerhead i will only be on the messengers for one more hour so if you could contact me that would be great! And if im not on please! email me here it is again locohammerhead@hotmail.com.
thank you,
Brandon Cook team 1256
Unread 13-01-2005, 11:04
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Team Role: Coach
Rookie Year: 1996
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: 3 wheel vs 4 wheel vs 6 wheel
Depending on your strategy, 3 wheel drive may be appropriate. The obvious problems with this concept are stability issues and less powered wheels on the ground. Advantages are higher manuverability and a lighter drivetrain than say a 6 wheel design.
In 1998 my team used a 3 wheel design, 2 powered wheels in the front and a caster in the middle back. In order to maintain stability we had .5" of ground clearance. In addition, we put small delrin skids on the bottom of the back corners in case they contacted the ground. As far as less powered wheels goes...We wanted to be quick and manuverable for that competition. While we had virtually no pushing power, we could escape from defensive machines using our manuverability.
My point is the following:
You should identify what qualities you want your drivetrain to have, and pick your design around them. List the advantages and disadvantages of each design. See if the advantages fir what you want, and see if you can come up with effective solutions for the disadvantages.
Remeber that people on your team will have vastly different ideas about what to do. Look to past robots from other teams for some inspiration on your ideas. Finally, compromise is sometimes the worst solution, you may have to give up on your idea, or convince others to commit to yours. It helps if you have some math or experiment results to back up the claims you make about your design ideas.
Good Luck,
Rob
Unread 13-01-2005, 11:57
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Brandon,
as others have suggested, the optimal drive design is a big "it depends".
There are many examples of real-world 3-wheel (or overhanging) designs such as engine lift cranes for automobile repair, or drum lifter cranes for 55 gallon barrels.
More importantly, it is vital that you and the team come to some concensus on your design and then put your best foot forward. By far, the biggest problem will be if you do NOT stick to some pre-determined strategy. You know that !#@$% will happen, but at least you can stay that you chose a design wisely and then executed flawlessly....win or lose.
Unread 13-01-2005, 12:16
well the team im on wants a arm that can turn 360 digrees and the 3 wheel desighn that they have in mind is really narrow and thats a big prob.
Unread 19-01-2005, 18:09
Gary C's Avatar
Gary C Gary C is offline
FRC #0968 (RAWC)
Gary C will become famous soon enough
Send a message via AIM to Gary C
Why not go ahead and build a circle for that matter.
Unread 19-01-2005, 19:00
Jeffel Jeffel is offline
AKA: Jeff Ellis
#0269 (Cooney Tech Robotics)
Team Role: Mechanical
Jeffel can only hope to improve
Send a message via Yahoo to Jeffel
treads are slow and they suck for quick turning and overall they suck and casters are horrible too. Its better to just use 4wd!
Jeff
Unread 19-01-2005, 19:19
663.keith 663.keith is offline
FRC #1493 (Falcons)
663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all663.keith is a name known to all
Send a message via AIM to 663.keith
treads can be very fast and easy to turn if done correctly. We have a robot that is by far the fastest we have built and he uses treads. conversely, one of our 4wd robots was terrible at speed, and could barely turn (it used a wonderful "Bounce turn"). I believe that treads work better than 4 wheels in many cases.
http://www.wcsrobotics.com
team 663
team 1493
Unread 19-01-2005, 22:05
AKA: Jeff Ellis
sorry but i'd still like to disagree on that one... i just dont like how the whole robot bounces around while turning on treads. sorry, never was a fan
Jeff
Unread 19-01-2005, 23:04
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
We did a three wheel chassis last year, two powered and a caster. We had no problem with tipping even when we went to raise yourselves up on the center bar.
4WD is good, but 6WD is better, if you have time and resources to pull it off.
Elknise
Issaquah Robotics
Unread 19-01-2005, 23:30
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
That depends on how you build it, if you drop the center portion of the tread (much like most 6wd designs with their center wheels), then turning on a tread drivetrain can be better than a 4wd platform. But if your treads are just 100% level, then there's a whole lot more side-friction to overcome compared to a 4-wheel drivetrain.
As for speed, that depends on your motors, gearing, and drivetrain efficiency.
We also had that problem with our 2003 robot, where would hop side to side when it would turn. It had too much traction and only weighed like 90 lbs.
Personally, I like 4wd, its a good balence between drive systems. Plus the kitbot is set up to do so.
EDIT: When I read 3wd, I actually thought you meant an actual 3WD robot with only 3 wheels, kinda like a kiwi drive platform. But if you're talking about a 2wd caster bot, I've always had bad experiences with them, but with some modifications, it can be good.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 20-01-2005, 00:56
MFS766's Avatar
MFS766 MFS766 is offline
FRC #0766
MFS766 is a glorious beacon of lightMFS766 is a glorious beacon of lightMFS766 is a glorious beacon of lightMFS766 is a glorious beacon of lightMFS766 is a glorious beacon of lightMFS766 is a glorious beacon of light
6-wheel is the best, but make sure the middle wheel is slightly lower (1/8 ish). This blends the 2wd and 4wd, all your weight is going to wheels with power so you should have good traction. It also centers more wieght on the center, oppose to the edges (farther from the turning point) of 4wd. This means 6wd takes less force to turn the robot. Also the wheel base is shrunk since amost only 4 wheels will be possible to signfigantly press into the ground. 4wd of the same shruken wheelbase are not stable. I saw many tip last year. Hey with 6 wheels, if it has problems, you can throw of wheels until you have 4wd of 2wd with a castor or two. It is easier to take away then add.
Unread 13-01-2005, 15:22
Parker's Avatar
Parker Parker is offline
FRC #1079 (C.R.E.A.T.E.)
Parker is an unknown quantity at this point
thank you,
What ever you do, don't use a pivot wheel!!!!!!!!!!!!!
My team used a pivot wheel last year and had major problems with steering. Our robot was incapable of backing up in a straight line. This screwed up our autonomous program.
If you do go with a three wheel design you should use a circular delrin skid.
As far as the number of wheels is concerned, that depends on your design. Personally, I'd use a four wheel drive robot because you get more power and it makes your drive train a lot more efficient.
Unread 13-01-2005, 16:01
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
3 wheel robot? or 3wd? slight difference. 2wd but with caster may be called a 3 wheel robot. a kiwi drive/killough platform 3wd robot would be really sweeet. a couple teams have already succeeded with those designs. and unstable.. well not necessarily. as loing as you have a nice big triangle it shouldnt be too unstable in itsself. just maybe a high cg will be bad. but that applies to all robots. and yes, as someone said. dont use swivel casters. omniwheels. skids, ball transfers, are a couple better options. but make sure if you use anything of the sort make sure they can support the weight. we destroyed a couple of our 'wheeliebarish' casters.
Unread 13-01-2005, 16:05
i_am_Doug i_am_Doug is offline
Currently foraging for food..
AKA: Doug
i_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura about
Send a message via AIM to i_am_Doug Send a message via MSN to i_am_Doug Send a message via Yahoo to i_am_Doug
what bout tread?
  #15   Spotlight this post!
Unread 13-01-2005, 16:07
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
thank you,
I'm not sure how much a bunch of random outsiders on some messageboard is going to sway the arguement in your favor. I think you guys need to test out the theories yourselves and find out what works and what doesn't.
