Go to Post Instead of giving us some wood and nails and saying "build us a box", they're handing us power tools and saying "now make us something cool" - galewind [more]
Unread 13-01-2005, 20:02
Gary C's Avatar
Gary C Gary C is offline
FRC #0968 (RAWC)
Gary C will become famous soon enough
Send a message via AIM to Gary C
Rotary Encoder (optical etc.)
Does anyone happen to know of a specific rotary shaft encoder (part number, source etc.) that will work with the default code that Dave Lavery discussed in the kick-off? It looked (and he mentioned) that the robot had an encoder on the gearbox output shaft of each side of the robot.
We would like something with a resolution of 500 ticks/rev or greater. It would also need to mount onto a shaft that is 1/2" or smaller. Lastyl, we would like to order two of them asap and would prefer not to have to create our own custom circuit.
Thanks!
Unread 13-01-2005, 20:10
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: Rotary Encoder (optical etc.)
Yes, mr kevin has the code on his site. Here are the two encoders that he has mentioned. You should download the encoder code and read the readme and the spec sheets for the encoders.
http://kevin.org/frc
His code was tested with "grayhill 63R256
and 61K128 quadrature output optical encoders."
Hope this helps
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 13-01-2005, 20:33
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Rookie Year: 1998
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
It looks like those encoders are available from digi-key, however it seems like they are not the hollow shaft style, which is much prefered.
Any other options?
Thanks!
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 15-01-2005, 03:59
Gasperini's Avatar
Gasperini Gasperini is offline
Mechanical Engineering Student
AKA: Kevin
#0968 (RAWC)
Gasperini is a jewel in the roughGasperini is a jewel in the roughGasperini is a jewel in the roughGasperini is a jewel in the rough
Send a message via AIM to Gasperini
We figured out the desired resolution without a problem, but are having trouble digesting the code. We're still learning about programming, and this is our first time with encoders.
Can you be more specific?
Unread 16-01-2005, 18:23
thoughtful's Avatar
Goto Mr.Kevin's FAQ
http://kevin.org/frc/encoder_faq.html
As it mentions that the optical output should be quadrature, i am very new to encoders;however, i think that as long as the output is quadrature you will be able to hook it up with the rc with some tweaking. I was looking around for some hollow shaft encoders, but didnt find one to my liking. If anyone knows a hollow shaft encoder or finds one please do post.
Edit:- Make sure you get a resolution that will suite you.
06-Team 1219 Mentor
encoder vs. motor stephenthe1 Programming 55 06-01-2005 22:07
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
Choosing an Encoder for the Drive-train MikeDubreuil Electrical 11 21-10-2004 00:50
Optical Sensors Used as Encoders? uvabrad825 Technical Discussion 22 03-05-2004 13:22
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
