Pinion not machined correctly
So, were putting the drivetrain and gear boxes together last night and we hit a snag. on the second gear box, the pinion (FRC-2005-112-005) on the small shaft is milled wrong. The center is twisted and will not go on to the shaft completely. Has anybody else run into this? How did you remedy the situation? Did you just buy a new one? Should there be a replacement at no cost to us? thanx
| rack and pinion. | greencactus3 | Pneumatics | 17 | 04-11-2004 23:24 |
| Converting the Bosch Metric Pinion into an English- Specification Pinion | evolution | Motors | 3 | 28-08-2004 16:30 |
| Removing Drill pinion | Rickertsen2 | Technical Discussion | 14 | 18-02-2004 13:41 |
| Drill Motor pinion | Justin Stiltner | Technical Discussion | 2 | 21-01-2004 02:43 |
| Chiaphua Motor Pinion Gear | Joe P | Inventor | 0 | 27-02-2002 15:48 |
