Go to Post I never had any doubt; good people who do good quality work will always prosper. - Gary Dillard [more]
Unread 14-01-2005, 08:37
pi_guy578 pi_guy578 is offline
Programmer/Electrician
AKA: Jake
FRC #0578 (Blue Lightning)
pi_guy578 has a spectacular aura aboutpi_guy578 has a spectacular aura about
Send a message via AIM to pi_guy578
Gracious Professionalism at your local hardware store
I don't know if any other teams are experiencing this problem but our team has searched through 9 hardware stores looking for PVC end-caps but can't find any. This is no coincidence IMHO. If your team is buying end caps and find some, DON'T buy ALL of them, especially if there is more than one team in your area. We want to get some planning and design idea's down, but don't have enough end caps to make tangible field elements and visualize what needs to get done.
Unread 14-01-2005, 08:44
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: Gracious Professionalism at your local hardware store
We had some trouble getting them and ended up getting 13 at our local hardware store (who we also ordered 100 more through for $.40 ea.) and we got 40 at Home Depot and 20 more at a hardware store near where one of our mentors works. We went to a few other hardware stores and another Home Depot which had none.
Your best bet is to order them if you cannot find them. Most people will probably be using all the ones that they buy, you should be able to order them and have them delievered relatively quickly (within a few days).
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 14-01-2005, 10:58
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Yeah, we had to order the ones we needed and there aren't a lot of team competing against us. We are getting 300 for 30 cents a piece and having 100 clovers made.
Unread 14-01-2005, 11:52
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
In a separate thread, I suggested that teams think "outside the box" as follows:
1) Do the practice field "goals" need to have the "proper" corners or can they use drilled-holes and nylon tie-wraps as connectors. I'll admit that the practice tetras should be as close to competition-spec as possible.
2) In our town (Rochester NY USA) all of the Home Depot, Lowes, and other big-box retailers were sold out. We considered using 1" PVC instead.
3) I happened to pass a bathroom showroom called "Ferguson"...then I got onthe web to find out that www.ferguson.com is one of the nation's LARGEST plumbing wholesalers and found out that they had over 500 1-1/4" endcaps in their regional warehouse; two days away from Rochester.
So....YES, gracious professionalism should exist at the store, but here's another way to extend that spirit.
ps: If only I had bought stock in PVC endcap-makers, I'd be rich.....
Unread 14-01-2005, 12:00
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Team Role: Coach
Rookie Year: 1996
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Share resources
In a situation like this, it might make sense for you to contact some local teams and collaborate with them. We have 3 teams in RI, but only 1 practice field. Get into contact with some local teams and work out a way to share some resources. Sharing resources will not only save some headaches when it comes to parts running out, but can also save you lots of money.
Good Luck,
Rob
Unread 15-01-2005, 01:12
RoboCat05's Avatar
RoboCat05 RoboCat05 is offline
The crazy Oompa Loompa
AKA: Catlin Level
FRC #0399 (LnHS Eagle Robotics)
Team Role: Driver
RoboCat05 is an unknown quantity at this point
My team had to go to a couple different hardware stores. We found one and they said go ahead and take as many as we needed which was really cool that they were wiling to let us clean them, but we didn't, we left them enough to keep stock for other customers. We only have one other team locally and they are like a half hour drive away.
Also for the clover my team just cut them out of .032 aluminum sheeting. They worked just like the real thing. And we didnt spend any money for because we had the material in our shop.
Unread 15-01-2005, 22:15
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
I 2 had the same problem at HOME DEPOT
However it was solved with 30 min of useless walking
When looking get the Pipes from electrical
Then go to plumbing to get the endcaps
Hope this helps some
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 15-01-2005, 22:22
ChiefDSOTM88's Avatar
ChiefDSOTM88 ChiefDSOTM88 is offline
#0088 (TJ^2)
Team Role: Student
ChiefDSOTM88 is an unknown quantity at this point
Send a message via AIM to ChiefDSOTM88 Send a message via Yahoo to ChiefDSOTM88
Were the only team in the area and we still cleared out our Home Depot... i bet many place will easily run out of PVC
AIM sn - PinkFloydDSOM72
Watch your step - This is a Moe Zone
Unread 15-01-2005, 22:45
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Well considering that there is 13 teams in the immediate area there is a good chance that the part is just plain out.
It does happen. I don't think anyone in Rochester is out to sabotage Blue Lightning's efforts.
Unread 15-01-2005, 22:49
Alex Salomonsky's Avatar
Alex Salomonsky Alex Salomonsky is offline
The A-Train
AKA: A-Train
#0769 (Eaglebotics)
Team Role: Student
Alex Salomonsky is on a distinguished road
Send a message via AIM to Alex Salomonsky
This is why I'm glad my teams to only team in Virginia Beach
Watch out for Landstown High School, Team #769 in 2005. this time i'm serious
I survived VCU
-Alex Salomonsky "The A-Train"
Unread 18-01-2005, 09:40
Twstdkittie's Avatar
Twstdkittie Twstdkittie is offline
You can't kill integrity
AKA: Kittie
#0384
Twstdkittie is on a distinguished road
Send a message via AIM to Twstdkittie
Yeah, Richmond's got like a thousand teams to compete with. And one of them has managed to swipe a bunch of the materials because there are only so many Lowes' in the area!
Rise inside, free your mind
Raise your fist to signify
We stand in defiance of hatred and deception
Unread 15-01-2005, 23:58
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
There are 4 home depots in my area, and they all sold out.
FYI.
We had to order online. Many people will.
--Petey
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 16-01-2005, 00:29
Anchi Anchi is offline
nekura
#1288
Anchi can only hope to improve
Send a message via AIM to Anchi Send a message via MSN to Anchi Send a message via Yahoo to Anchi
it would be prety funny if corprate knowtesed and uped the number all stores have in stock then all the sudden noone needs them. heh
"If knowlage is power, dose that make me a weapon of mass destruction?"
"Everyone is entitled to their own worthless opinion, only mine is important."
Unread 16-01-2005, 00:53
Roland's Avatar
Roland Roland is offline
Post-A-Holic
#1466
Team Role: Webmaster
Roland is infamous around these partsRoland is infamous around these partsRoland is infamous around these parts
Could be worse, remember the fiasco with the balls last year.
  #15   Spotlight this post!
Unread 16-01-2005, 01:26
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
We found our in the plumbing section. We are going to look at an electrical supply house to see if we can find the flat end caps similar to what is going to be used at the competition.
If your local home depot doesn't have them, try an electrical or plumbing supply place. They are sure to have a lot more in stock than a hardware store.
Elknise
Issaquah Robotics
Gracious Professionalism of 498, 696, & 80 Penny Thanks and/or Congrats 7 22-03-2004 01:27
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
What is gracious professionalism really? A. Snodgrass General Forum 9 20-03-2003 05:53
Gracious Professionalism Award Redhead Jokes Regional Competitions 3 10-03-2003 14:53
An abundance of gracious professionalism.... archiver 2000 0 23-06-2002 22:36
