Go to Post good to have you on board the Circus Train Jane - Wayne C. [more]
Unread 20-01-2005, 13:41
RIgnazio RIgnazio is offline
Team Role: Webmaster
RIgnazio will become famous soon enough
Exclamation IMPORTANT MESSAGE ABOUT CMUCAM2!
But do not forget this:
You CAN NOT use the camera servo outputs to power the angling servos for the camera. If you wish to have the camera move on its own, those outputs must go through the FRC Controller, and the FRC Controller must control the servos.
See Section 5: The Robot (http://www2.usfirst.org/2005comp/Se...5-The_Robot.pdf)
<R53> Custom Circuits may not:
• Interfere with the operation of other robots
• Directly affect any output devices on the robot, such as by providing power directly to a motor, supplying a PWM signal to a speed controller or supplying a control signal to a relay module. (Custom high impedance voltage monitoring or low impedance current monitoring circuitry connected to the robot’s electrical system is acceptable, because the effect on the robot outputs should be inconsequential.)
• Be used for wireless communication, such as sending or receiving a signal to and/or from the alliance station
• Connect to the radio or tether ports on the Robot Controller
Just to help you avoid headaches in the future.
Also, If you go to www.ifirobotics.com and look at the details for the camera, it states for the servo outputs "Not typically used in FIRST competitions" or something to that nature.
Unread 20-01-2005, 13:45
Rocketboy's Avatar
Rocketboy Rocketboy is offline
Programmer at work, Pilot by heart
AKA: Daniel Schoessler
FRC #1317 (Digital Fusion)
Rocketboy will become famous soon enough
Send a message via ICQ to Rocketboy Send a message via AIM to Rocketboy
Re: IMPORTANT MESSAGE ABOUT CMUCAM2!
Thanks for the heads-up
-- Unofficial Google Advocate --
I soloed my
"Skyhawk" before I even soloed my car!
Unread 20-01-2005, 13:48
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Team Role: Leadership
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
This may be a technicallity, but I thought if it's included in the kit, then it's not a custom circuit? Since all teams get one of these in the Kit, noones at a disadvantage. Is there something I'm missing?
Alex
President
Team 1072 Harker Robotics
Unread 20-01-2005, 13:49
No problem. I had posted in a section with Programming, but the topic was closed. (I guess I was a little off topic) I was told to post in Rules.
Unread 20-01-2005, 13:52
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Yes you can. There have been several threads on this subject already, and it has been asked and answered on the FIRST Q&A.
{edit} Looks like someone merged this with the other thread that was already talking about this subject after I posted this. {/edit}
ID: 1183 Section: 5.3 Status: Answered Date Answered: 1/17/2005
Q: May we connect servos to the PWM outputs on the CMUcam to take advantage of the automatic pan and tilt control that it provides
A: Yes. Servos connected to the camera module are considered part of the camera module and can only be connected to it.
Unread 20-01-2005, 14:28
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: Is the suggested Vision Camera setup ILLEGAL?!
I have merged these 2 threads to make 1 of the same.
We do not stop playing because we grow old;
we grow old because we stop playing.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Camera Problems pickle Programming 21 20-01-2005 20:43
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
