How do you connect multiple CIM motors to the Robot Controller
from my point of view of the diagram it seems that to connect the motors from one victor speed controller is it possible to use just 1 speed controller for multiple CIM motors or do you need multiple speed controllers? -if I need more speed controllers where will I connect the speed controllers to? thank you! Any help will be appreciated! PS. is any of the diagrams(ie. speed controller, Robot contoller,etc.) on the Robot Power Distribution diagram available to make a custom diagram? thanks again for any help! ![]() |
Re: About Robot Power Distribution Diagram
<R77> No more than 1 motor may be connected to each speed controller.
If I remember correctly, the robot controller should have 16PWM outputs on the top (you can see them at the top of the RC in the diagram), meaning you can connect 16 speed controllers to those outputs. |
FIRST puts only 1 of each kind of motor to show what it should be connected for the sake of keeping the diagram uncluttered. Repeat how each device is connected if your using more than one.
thank you for your help!
| Winning Robot or Quality Robot? | Eric Bareiss | General Forum | 30 | 09-02-2006 13:19 |
| How much planning goes into your robot? | Jnadke | General Forum | 41 | 29-01-2006 21:29 |
| A Question on Sportsmanship | Steve M | General Forum | 31 | 25-05-2004 23:52 |
| Operator Interface power ISSUE | kacz100 | Technical Discussion | 11 | 27-02-2004 13:46 |
| about how Drive Train push the robot... shouldn't the force accelerate the robot? | Ken Leung | Technical Discussion | 12 | 26-11-2001 09:39 |
