Go to Post This reminds me of a sports bar where there's a bunch of games on different TV's. Only this is better because it's FIRST. :D - JackG [more]
Unread 15-01-2005, 12:48
hedgehogger hedgehogger is offline
hedgehogger can only hope to improve
Problems and questions about programming
Hey,
First i cant get the new compiler to install on XP and if you cant tell im a newbie to programming so if i can get a step by step and if i have to remove anything and add sumthing let me know.
Where can i find the code to the camera sensor so i can practice and tinker with it........
thanks
-Hedgehogger
Unread 15-01-2005, 13:12
neilsonster's Avatar
neilsonster neilsonster is offline
AKA: Andrew Neilson
FRC #0772 (Sabre Bytes)
neilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to all
Send a message via MSN to neilsonster
Re: Problems and questions about programming
Here is a great guide to getting your compiler up and running. It's a few megabytes so give it time to load if you have a slow connection.
I myself have only started tinkering with the camera code and controlling motors with it and whatnot. I'm pretty sure most of what you'll be using for the camera is in user_routines.c. From what I have found most of the stuff that communicates the camera with the rest of your robot is in here. Look for lines like this: "#if _USE_CMU_CAMERA" in the code to find sections relating to the camera.
Also, be sure to download this guide. It has code explanation, a getting started guide, the GUI for calibrating the camera, and the 71-page user guide.
Unread 15-01-2005, 14:01
Hey again
um... did they give us a new default code this year and if so where is it at???
thanks
-chris
Unread 15-01-2005, 18:17
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Originally Posted by hedgehogger
Hey again
thanks
-chris
http://www.ifirobotics.com/rc.shtml down at the bottom.
(Direct download: http://www.ifirobotics.com/docs/frc-...2-2005v2.4.zip)
Unread 15-01-2005, 18:18
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
Hey again
thanks
-chris
The code is located at: http://www.ifirobotics.com/rc.shtml#Programming
Make sure you have downloaded the new master code (also located there) and installed the new C compiler and MPLAB development environment. MPLAB can be found at: http://www.microchip.com/stellent/id...&part=SW007002 and the compiler has a link on the FIRST website.
This has also been discussed here: http://www.chiefdelphi.com/forums/sh...ad.php?t=32842 see that thread for more information.
FRC Volunteer, FLL regional planning committee member for Colorado
Former Programmer, Web Designer, Communications Director of Alpine Robotics Team 159.
Add your team to the FIRST Teams Google Map
2 questions (programming) Brawler006 Programming 20 22-02-2004 23:15
A few questions on programming the Control System Avarik Control System 21 08-02-2004 11:42
Questions regarding textures in 3D Studio Max Ryan Dognaux 3D Animation and Competition 6 16-02-2003 14:26
Pneumatics parts list questions archiver 2000 1 23-06-2002 22:48
Problems rendering Tyler Olds 3D Animation and Competition 8 24-01-2002 22:34
