Go to Post I bet a lot of us (mentors and students) got into this line of work first because we wondered how things work, and stayed in it because we thought "I can make that work better". Thus starts a life-long battle between perfection and time. So far, time is ahead. - petek [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 15-01-2005, 13:10
Vashts6583's Avatar
Vashts6583 Vashts6583 is offline
The sleepless
AKA: Rob Metzger
FRC #0007 (Team 007)
Team Role: Leadership
Vashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to all
Send a message via ICQ to Vashts6583 Send a message via AIM to Vashts6583 Send a message via MSN to Vashts6583 Send a message via Yahoo to Vashts6583
Question Can anyone explain to CAD to me?
Yeah. I'm a sophomore with no experience whatsoever on Computer Aided Drafting or anything of the sort. We have autodesk(R) here at the school, but I have no clue how to use it. Can anyone explain to me how to use it?
2005: Software Assistant
2006: Software Head
2007: President/Driver/Software Head/Temporary Safety Captain
//2005: Chesapeake Regional - Finalist
Life is what you do outside of FIRST. No wonder it's so short.
Unread 15-01-2005, 13:13
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: N00B 0N C4D...H0W D035 I7 W0RK?
Try using the tutorial lessons included with the software.
P.S. spelling things at least semi coherently will help people to not just ignore your threads in the future
2001-2004: Team 100
2006-Present: Team 254
Unread 15-01-2005, 20:55
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Re: Can anyone explain to CAD to me?
First, which Autodesk CAD program are you refering to: Inventor or AutoCAD? Inventor is a 3D solid modelling program and AutoCAD is a 2D/3D design program. Either can be used to design stuff - like robots.
In both cases you start a design by drawing a flat, 2D "projection" of a part and then add to that, either by making it into a 3D model or by adding different views to show what it looks like from different angles. In any case, the final result is a set of drawings or a computer file which describe what the manufactured part should look like.
Autodesk included some very good tutorials with Inventor which will get you started in the right direction. If you plan to use Inventor do them first. They're in the Open screen under Getting Started - click on "Learn how to build models quickly" and work your way through the lessons. You'll be glad you did.
AutoCAD takes a little more work to get up to speed on. I expect there are some good tutorials out there for it, but I haven't run across them. Maybe someone else on CD can point to them?
A good place to look for more info on Inventor is: http://www.sdotson.com/
Post back if you need more general info. We'll be happy to help.
Pete
Pete Kieselbach
Unread 16-01-2005, 14:04
rmmlg's Avatar
rmmlg rmmlg is offline
#0900 (Infinity)
rmmlg is on a distinguished road
You might also want to consider getting a book or finding some other tutorials in addition to the tutorials that come with the software. It's always best, though, to find someone to check your work when you are learnign to make sure you are doing things correctly.
Ryan
Team 900 (Infinity)
Unread 16-01-2005, 18:17
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
its kind of hard to teach someone, especially through a forum. The totorials (spelling) are pretty good. Im teaching myself inventor right now. The books out there are great, most of them. I have used a bunch while working in my CAD II and III class. Just play around with the software. Theres alot to learn.
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
The New and Improved FIRST CAD Library Ed Sparks General Forum 22 03-02-2007 18:03
CAD on your team? SpaceOsc Inventor 25 18-11-2004 11:14
CAD Portfolio? Madison Career 9 20-10-2004 12:45
First Logo as a CAD file jrgrim12 Inventor 4 14-02-2003 11:42
CAD Drawings? archiver 1999 17 23-06-2002 22:35
