Go to Post If you're the smartest person in the room, you're in the wrong room - Ian Curtis [more]
Unread 15-01-2005, 21:56
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Rookie Year: 1999
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Kitbot/cims/transmissions running too slow?
We had our kitbot running today and did a speed test.
Our configuration was using 6" wheels.
also used the 21 tooth for the counter shaft
and the 28 tooth for the wheels
we measured it's speed to be 5'/sec
If you figure those cims are running at 5300 free speed
reduced 12.75:1 (gear) and 1.333:1 (sprocket)
we should have been moving 8.15'/sec
There wasn't much if any efficiency loss in the way we had it assembled, and the speed test was fairly accurate +/- .5 sec
I'm thinking those cims are turning more like 3300 rpm
Has anyone else experienced this?
Originally I thought everyone using the kit chassis/trans. and 8" wheels would be up in the range of 10.5'/sec but after seeing this, it's looking like they'll be traveling more like 6.5'/sec
One thing I didn't check (as I'm thinking of it now) is that we may have not been applying full power to the speed controllers, as we just grabbed an old RC and ran it. But I doubt the code wouldn't be full power.
edit: reduction ratio (oops)
www.179swampthing.org
Unread 15-01-2005, 21:59
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
Re: Kitbot/cims/transmissions running too slow?
CIMs are 5342 rpm no load according to the spec sheet. No load means no load. Wheels, a gearbox, chains, etc, are a load.
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 15-01-2005, 22:07
Swampdude's Avatar
AKA: Dan Quiggle
Rookie Year: 1999
Yah, of coarse there's going to be some loss, but over a 1/3?
and this test was giving it a good 10' of room before the start line with no load other than the chassis, and the gear reduction as you said. I could understand 1/10 loss but not 1/3.
Unread 15-01-2005, 22:12
Fold em oval!
If i'm not mistaken
5 ft per sec /(6"*pi/12)*60sec/min = rpm of wheels = 191
191 rpm * 2.63 * 12.75 = 6404 rpm at the CIM
I'm not sure what you mean by counter shaft, but assuming you mean the pinion sprocket (is that the proper term?) the sprocket ratio is 28/21, you have
191 rpm * 28/21 * 12.75 = 3247 rpm at the CIM
which is it?
Team 1257
Unread 15-01-2005, 22:36
Hieb Hieb is offline
Team Role: Teacher
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
I haven't put your numbers in, but I designed a spreadsheet based off of JVNs' motor calc sheets in the whitepapers, and from that I get an approximate speed of of 6.5 ft/sec for a full weight (120 lb) robot using the transimission as given. While the 8.15 ft/sec may be accurate with no load, you have to account for all of your weight as well.
Unread 15-01-2005, 22:41
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
The robot is actually closer to 134-136 lbs... you have to account for the battery in the physical weight even though you dont in weigh in
2001-2004: Team 100
2006-Present: Team 254
Unread 15-01-2005, 22:43
Swampdude's Avatar
AKA: Dan Quiggle
Rookie Year: 1999
I assume your figuring on 6" wheels?
I think our assy weighs around 40lbs
I'd like to see what you're using from John's spreadsheet that adds the loss in weight.
Unread 15-01-2005, 22:59
Fold em oval!
there should be no (or almost no) loss in top speed because of weight. The only tiny bit of loss from weight would be the added resistance it puts on the bearings, but in every FIRST drivetrain i have seen, the bearings are well well below there ratings.
Team 1257
Unread 15-01-2005, 23:01
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
By weight I think he means the load that the motors have to push.
Unread 15-01-2005, 23:02
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
Dan,
Allow me to perform an analysis for "our viewers at home".
My calculations match your analysis:
The weight will have minimal affect on the top speed. The only difference will be an increased normal force on all wheel/wheelshaft bearing surfaces, which will increase friction slightly.
This increase in parasitic loss is negligible.
Therefore, we can simply eliminate weight from our analysis.
Please refer to the attached spreadsheet.
This sheet shows the speed of the robot at 8.47fps (assuming 100% efficiency). From here, we can increase the "speed loss constant" to 60% which then shows an output speed closer to what Dan is experiencing.
This means, (as Dan stated) the CIM motors are either spinning slower than expected, or there is a large parasitic loss in the gearbox.
If we assume no parasitic loss, we need to find out reasons for a slower spinning CIM.
Some reasons:
-Voltage provided to the motor is closer to 7.2V
-Motor is wound differently, and top speed is limited.
I would almost immediately rule out a motor flaw.
Dan, please recheck your voltage. If that fails, replace the Chip motors and see if the problem persists.
Thanks,
John
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
Unread 15-01-2005, 23:12
Swampdude's Avatar
AKA: Dan Quiggle
Rookie Year: 1999
John,
Have you (or anyone you know) performed a speed test on this equipment and found it to perform as expected?
Unread 15-01-2005, 23:16
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
Rookie Year: 2000
John,
Yessir.
Paul Copioli performed testing on first articles from production as well as the original prototypes. FIRST Engineering also performed testing.
Everything functioned fine.
If it's not the motor voltage, I'll buy you a dew.
JV
Unread 15-01-2005, 23:29
jimfortytwo jimfortytwo is offline
AKA: Jim Paulos
#0418 (Purple Haze)
Team Role: Student
jimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nice
Send a message via ICQ to jimfortytwo Send a message via AIM to jimfortytwo Send a message via Yahoo to jimfortytwo
For what its worth, I have compared free speed extrapolations to ground speed measurements for all the robots presently in our "garage." The trend is pretty obvious.
2001: two 3/8" drill motors
32% 6ft/s real, 18ft/sec projected
2003: two 1/2" drill motors in high
38% 10.5ft/s real, 27ft/sec projected
(resulted in intermittent breaker and controller resets!! )
2003: two 1/2" drill motors in low
68% 5.6ft/s real, 8.2ft/sec projected
2004: two 1/2" drill and two CIM
78% 7ft/sec real, 9ft/sec projected
You can see that our "speed efficiency" rose dramatically once my team started choosing reasonable gear ratios. If you were to take these speeds and work backwards to the assumed load on the motor to get that speed, and the resulting current draw... the currents are astronomical, obviously. I hate to think what was happening while we were turning. I've always wanted to use a clamp on meter to find out if all this empirical data is self-consistent.
Oh, and for all of these tests I also did a "wheels off the floor" rpm measurement, which without fail was very very close to the free speed expected. Take this measurement, and just see if robot weight on those axles doesn't somehow make a difference.
As far as our measurement methods, we timed the robots on the ground over a 50 foot window following a 30 foot accelleration zone. I imagine that was fairly accurate.
Given this history, my adjusted calculation to estimate the speed of our kit-built competitors was 6.3 ft/sec.
Unread 16-01-2005, 12:35
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
I tested the living daylights out of that gearbox. I tested the 4wd configuration with 8 inch wheels and it behaved as expected (around 9.5 ft/sec). I use a closed-form non-linear differential equation to solve for position, speed, and acceleration over time and it tracked exactly with my testing of the frame.
What type of six inch wheels are you using?
What type of bearings?
How much chain tension do you have?
Something is not quite right.
-Paul
  #15   Spotlight this post!
Unread 16-01-2005, 12:46
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Rookie Year: 1997
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
For the past several years, Team 33 has been able to get our robots to reach over 90% of the theoretical free speed. If you are only getting 60%, something is wrong. Easiest way to find it: remove the chip motors and check for friction. Without the motors in the system, everything should spin freely when you turn the wheels by hand. If it doesn't, figure out why.
"To learn what is possible, we must attempt the impossible." Arthur C. Clarke
Could FIRST be updating there website it is running extremely slow. Mr.G Chit-Chat 3 01-01-2005 21:22
Running OSX 10.3 on a Macintosh Centris Joe Matt Chit-Chat 4 27-10-2004 00:37
How slow is too slow? Joe Ross Rules/Strategy 23 12-10-2004 20:23
Dual sites on home server running apache? Mike AA IT / Communications 7 28-08-2004 02:02
A vampire running for office MissInformation Chit-Chat 2 30-08-2003 14:36
