Go to Post I'm down with banning the Chicken Dance (and take the Macerena with you when you go)! - Koko Ed [more]
Unread 16-01-2005, 19:10
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Camera fails to output anything on serial lines
I've wired up the camera - I'm using the 2002 mini RC for power, and I then hooked up the camera and serial lines. Upon powering up, all three status LEDs turn on and the servo twitches. Very quickly, the green status LED (the one to the left) turns off, leaving the green power LED and the red status LED on. Nothing appears on my terminal. I tried typing 'gv' as was suggested by the directions to no avail. The GUI fails on any command, often crashing in the process. I'm providing about 7V of power, more than the minimum 6. I have no clue where to go from here - how else can I go about debugging the camera? Thanks,
Steven
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
