Go to Post Our robot throws custom $5.50 FIRST Frisbees at a rate of 75 discs per minute and a speed of ~32 feet per second. It costs over $80 to feed our robot for 12 seconds. - Woolly [more]
Unread 25-03-2002, 19:14
Guest
Posts: n/a
Question How do you attach a wheel to a shaft?
Our dimensions for the wheels are: 6" diameter
Shaft is 1/2" diameter.
We need to know very quickly!!!
Unread 25-03-2002, 20:24
thedillybar thedillybar is offline
#0894 (Chargers)
thedillybar is an unknown quantity at this point
Send a message via AIM to thedillybar
What's the wheel for? Drivetrain or something else? Do you need it to handle a lot of torque and a lot of speed or no?
Unread 25-03-2002, 21:33
Joe3's Avatar
Joe3 Joe3 is offline
Joe3 has a spectacular aura aboutJoe3 has a spectacular aura aboutJoe3 has a spectacular aura about
Send a message via AIM to Joe3
Depending on the wheel interior diameter- you would probably want to use a traintorque.
Unread 25-03-2002, 21:58
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
What not to do...
Heh - don't hot glue a motor to a shaft and then the shaft directly to the wheel ... a kid at our school (now a team member) found that it didn't work too well for his electronics and robotics class...
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 25-03-2002, 22:05
Joe3's Avatar
gluing motors
I really hope you are kidding. That would be funny though
Unread 26-03-2002, 01:11
Haha!
No, unfortunately I'm quite serious! One of our engineers picked up the wheel/shaft/motor and asked, "Who did this?" Then kind of sarcastically said, "Some kid not on the team?" and I said, "Well... no... he joined last week... he's sitting over at that computer..." It was quite funny. I never got to see their machine run, heehee! I wonder if it ever did... :::shrugs:::
- Katie
Student - 2001-2004
Mentor - 2006-2009
Unread 26-03-2002, 11:07
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is online now
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
Wheel to Shaft
SilverStar,
I am assuming the whell is either for a drive wheel or a ball shooter wheel. In either case, a 1/2" trantorque may do the trick. Go to this website: www.fennerdrives.com
The Torque rating for 1/2" TranTorque is 350 in-lbs (~40 N-m)
The Chiaphua motor with an 18:1 gear ratio is about 40 N-m of output with no safety factor.
Hope this helps.
-Paul
Unread 26-03-2002, 16:38
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
Lightbulb
This year our shafts are steel while our wheels are aluminum. To attach we welded a 'yoke' to the shaft then bolted the wheel to it this is the strongest method we have for dissimilar metals. Metal to metal we welded. I like trantorques also they work well as long as you have good tolerances. Also not sure how they work if the wheel was plastic probably not well. If you need more help post the materials of what you are connecting and someone can offer robust advice.
Unread 26-03-2002, 18:27
Guest
Posts: n/a
Re: Wheel to Shaft
Originally posted by Paul Copioli
SilverStar,
Hope this helps.
-Paul
I'll try that...
Unread 26-03-2002, 18:31
Guest
Posts: n/a
Doesn't look like that's going to work for us.
The bearings are still in the wheel.
We're going to use clotting pins through the wheels and the rods.
Unread 26-03-2002, 19:53
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Rookie Year: 2000
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Pins are bad, if there is alot of torque we have had some realllly bad problems with pins breaking in the past. would advise asgainst it.
Andrew
Unread 27-03-2002, 19:56
Guest
Posts: n/a
Okay, not using pins.
Still we need more suggestions, trantorque won't work for us...
Unread 28-03-2002, 13:59
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
SHow a sketch...
It is hard to recommend a solution when we can't really see the problem.
Do you have a picture or can you scan in a sketch of your set up?
Joe J.
P.S. If you are using Skyway wheels, we have had good success chucking the wheels up on a lathe, boring out the center hold to a whole number (1 1/8 for example), then pressing in shaft and pinning the shaft to the wheel. The larger diameter hole makes pinning an easier thing to deal with.
Another method is to use the Small Parts Inc. adaptors.
Yet another method is to use bolts and spacers. If you have a sprocket that you can get the torque to, then go directly to the wheel spokes with the torque rather than going to the shaft and then from the shaft to the wheel. One way to do this is to put bolts into the sides of the sprocket. Use the spacers to key the bolts perpendicular to the sides of the sprockets. It can work well.
Finally, give us a sketch or a picture to work with and we will have better ideas to share.
Unread 30-03-2002, 20:26
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
Rookie Year: 1999
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Andrew
Pins aren't always bad if you make sure they have a large enough radius to withhold the maximum applied load. However, if you use pins you should be careful... Depending on the setup, the material around the pin may actually be a lot more susceptible than the pin itself. Lots of time, the material around it will yield (deform to a great enough extent that when the load is released the material does not regain it's original shape). As a result, lots of times the pins will fall out because the pin is no longer a press-fit and is loose. I've seen a number of cases in my years with first where pins fall out during matches or at the worst possible times. I've never seen a pin break although it certainly can happen.
There are also many ways to use pins. You can place them in a number of different geometries, each having certain advantages and disadvantages. I've done a bit of research into pins for a class I'm taking so if you would like I can post all the different types of pins you can use and how to make the associated stress calculations.
- Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
  #15   Spotlight this post!
Unread 31-03-2002, 15:14
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
Hm, so is there some advantage to locking a wheel and sprocket to a shaft as opposed to locking a sprocket right onto the wheel (a la wheel hub)?
We've always used the SPI hub kits, and just let the wheel ride on it's bearing on a shaft...
Who used wheel encoders CyberWolf_22 Technical Discussion 12 04-05-2003 15:37
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
Motor coupling archiver 2001 19 23-06-2002 23:35
shaft drive Joseph F Technical Discussion 5 03-02-2002 17:51
wheel drive Greg Needel Technical Discussion 3 29-01-2002 12:12
