Hello,
What are the dimensions for the operator shelf (i.e. the place you set your control board for the driver) I know in one post it said the aluminum shelf was 12" deep and 12' long. Does this mean each team has roughly 4' length to work with? Thank you, Jesse K. Team 1317 |
Re: Operator Shelf Dimensions
The Operator Interface Console designed by your team must fit on the 69” wide by 12” deep shelf in the Alliance Station and the radio modem connected to the Operator Interface must be able to reach the mounting bracket on the operator stations. Be sure to leave at least 48” of slack in the 9-pin cable.
The shelf is also 34" off the floor.
Be aware that if you plan on pushing the limit the 69" wide includes the emergency stop box. |
| Bosch Drill Motor Clutch Spring Dimensions?? | aaronbr28040 | Motors | 3 | 18-02-2004 19:52 |
| Beacon and 10 Point ball PVC frame dimensions | MrB | General Forum | 2 | 28-01-2004 08:35 |
| Can LEXAN exceed robot dimensions? | RAWdealer59 | Rules/Strategy | 13 | 05-03-2003 22:05 |
| Robot dimensions & weight restrictions revealed? | Mike Soukup | Rules/Strategy | 4 | 24-10-2001 20:51 |
| Field and shelf missing dimensions | kmcclary | Off-Season Events | 3 | 12-10-2001 18:21 |
