Thread Tools |
Rating:
Display Modes |
Example gyro code released.
I've written example gyro interface code and posted it here: http://kevin.org/frc. This code has been substantially revised since the version released earlier with the PID and scripting code. A substantial amount of documentation has also been written to support this code. As the programming interface has changed, this code will not work with the current version of robot.c. An updated version of robot.c will be released soon.
Here's the readme.txt: Code:
The source code in gyro.c/.h contains a driver and supporting software to interface a variety of inexpensive gyros to your robot controller. This software was tested with Analog Devices' ADXRS150EB and ADXRS300EB gyros. Data sheets for these devices are included. Support for the ADXRS401EB is also included. By default, this software is configured to work with a ADXRS150EB gyro, sampling at 400Hz, downconverting to an update rate of 50Hz by averaging eight samples per update. These parameters can be changed by editing gyro.h. This software makes the assumption that when it's running, it solely controls the analog to digital conversion hardware and that only the gyro, on analog input one, is being sampled. Calling Disable_Gyro() will disable the gyro software and allow you to use the ADC for other purposes. This source code will work with the Robovation (A/K/A EDU-RC) robot controller and the FIRST Robotics robot controller. Wiring-up the ADXRS401EB, ADXRS150EB and ADXRS300EB gyro evaluation boards is straightforward. Grab a PWM cable and cut off the male end and strip the three wires back a centimeter or so. With a low wattage soldering iron, solder the white wire to the RATEOUT pin, solder the black wire to the AGND pin, the red wire to the AVCC pin, and finally connect a jumper wire between the AVCC and PDD pins. Plug the female end into the robot controller's analog input 1. For optimum performance, you'll need to calibrate the scaling factor to match that of your gyro's. One way to calibrate your gyro is to mount it very securely to a hefty, square or rectangular object. Mounting the gyro to a hefty object will help dampen higher frequency vibrations that can adversly effect your measurements. Place the mounted gyro against another square object and start the included demonstration software. To get good results, the mount must be absolutely still when the "Calibrating Gyro Bias..." message appears on the terminal screen. After a few seconds, the gyro angular rate and angle will be sent to the terminal screen. If the angle drifts rapidly while the mounted gyro is motonless, you need to restart the software to acquire a new gyro bias measurement. Again, gyros are very sensitive and must be still while the bias is calculated. Once the gyro is running with little drift, rotate the mount 180 degrees and note the reported angle. If the angular units are set to tenths of a degree, the ideal reported angle is 1800. If set to milliradians, the ideal angle 1s 3142 (Pi times a thousand). For every tenth of a percent that the angle is high, decrease the GYRO_CAL_FACTOR numerator by one. Conversly, for every tenth of a percent low, increase the numerator by one. Repeat until you're satisfied with the accuracy. If you find that the Calc_Gyro_Bias() function doesn't do a good enough job of calculating a bias for your particular gyro, another option is to average the gyro bias for a much longer period of time and manually set the gyro bias using the function Set_Gyro_Bias(). An example that shows how to do this is commented out in the accompaning user_routines.c/ Process_Data_From_Master_uP(). With a perfectly still gyro, running this example code will display a running average gyro bias that should converge to one value over time. Enter this value into the call to Set_Gyro_bias() and comment out or remove the call to Calc_Gyro_Bias(). Now perform the gyro scaling factor calibration described above. The included project files were built with MPLAB version 6.60. If your version of MPLAB complains about the project version, the best thing to do is just create a new project with MPLAB's project wizard. Include every file except: FRC_alltimers.lib and ifi_alltimers.lib and you should be able to build the code. **************************************************************** Here's a description of the functions in gyro.c: Initialize_Gyro() This function initializes the gyro software. It should be called from user_routines.c/User_Initialization(). Get_Gyro_Rate() This function returns the current angular rate of change in units of milliradians per second. If desired, the angular unit can be changed to tenths of a degree per second by modifying the angular units #define entry in gyro.h Get_Gyro_Angle() This function returns the change in heading angle, in milliradians, since the software was initialized or Reset_Gyro_Angle() was called. If desired, the angular unit can be changed to tenths of a degree by modifying the angular units #define entry in gyro.h Calc_Gyro_Bias() This function forces a new gyro bias calculation to take place. For best results, this should be called about a half second after the robot powers-up and while the robot is perfectly still with all vibration sources turned off (e.g., compressor). It's a good idea to call this function whenever you know the robot will be completely still for about twenty-five milliseconds. For example, call this function just after you've completed a straight line drive, and just before doing a turn-in-place. Get_Gyro_Bias() This function returns the current calculated gyro bias. For extra precision, this software internally maintains a gyro bias value that is the sum of GYRO_SAMPLES_PER_UPDATE samples of the gyro's analog output. By default, GYRO_SAMPLES_PER_UPDATE is set to a value of eight in gyro.h Set_Gyro_Bias() This function can be called to manually set the gyro bias. For extra precision, this software internally maintains a gyro bias value that is the sum of GYRO_SAMPLES_PER_UPDATE samples of the gyro's analog output. By default, GYRO_SAMPLES_PER_UPDATE is set to a value of eight in gyro.h Reset_Gyro_Angle() This function resets the integrated gyro heading angle to zero. Disable_Gyro() This function should be called when the gyro functionality is no longer needed, thus reclaiming the time spent servicing the timer 2 interrupt. Initialize_ADC() This function initializes the analog to digital conversion hardware. This is called by Initialize_Gyro() above and shouldn't be called directly. Initialize_Timer_2() This function initializes and starts timer2. This is called by Initialize_Gyro() above and shouldn't be called directly. Timer_2_Int_Handler() This function is automatically called when timer 2 causes an interrupt and shouldn't be called directly. **************************************************************** Six things must be done before this software will work correctly on the FRC-RC: 1) The gyro's rate output is wired to analog input 1. 2) A #include statement for the gyro.h header file must be included at the beginning of each source file that calls the functions in this source file. The statement should look like this: #include "gyro.h". 3) Initialize_Gyro() must be called from user_routines.c/ User_Initialization(). 4) The timer 2 interrupt handler, Timer_2_Int_Handler(), must be installed in User_Routines_Fast.c/InterruptHandlerLow(). See the accompanying copy of User_Routines_Fast.c to see how this is done. 5) You must select the gyro you're using from a list in gyro.h and if needed, remove the // in front of it's #define. 6) For optimal performance, you'll need to calibrate the gyro scaling factor using the instructions above or those included in gyro.h. Eight things must be done before this software will work correctly on the EDU-RC: 1) The gyro's rate output is wired to analog input 1. 2) IO1 must be configured as an "INPUT" in user_routines.c/ User_Initialization(). 3) The call to Set_Number_of_Analog_Channels() must configure at least one analog channel. 4) A #include statement for the gyro.h header file must be included at the beginning of each source file that calls the functions in this source file. The statement should look like this: #include "gyro.h". 5) Initialize_Gyro() must be called from user_routines.c/ User_Initialization(). 6) The timer 2 interrupt handler, Timer_2_Int_Handler(), must be installed in User_Routines_Fast.c/InterruptHandlerLow(). See the accompanying copy of User_Routines_Fast.c to see how this is done. 7) You must select the gyro you're using from a list in gyro.h and if needed, remove the // in front of it's #define. 8) For optimal performance, you'll need to calibrate the gyro scaling factor using the instructions above or those included in gyro.h. |
Re: Example gyro code released.
Thanks a lot! That's all I can say! ![]() |
Nice! good thing we already ordered our gyro
![]() Once again thankyou for the great code ![]() |
How could I use this with the accelerometer?
Does anyone know the sample rate for it? |
Has anyone tried this code yet? I'd like to get a sense of how (if) it's working for teams.
-Kevin |
First of all, thank you for your undying effort keeping this huge event on track. I just started this year as a programming mentor and do not know the ins and outs of what has happened over the last few years with the code. The programming student on the team is new, and he is a little anxious with everything. He first saw "C" just a few weeks ago and is feeling a little overwhelmed. I am guiding him through how to layout the functionality he needs to meet the required game rules and translate all of that into working code. In one of your previous posts, you stated you were working on a new robot.c (and I hope a new robot.h). Do you have any idea when we would see that? Having that will help immensely since my role is to help and not perform the actual work instead of the student doing it himself. Respectfully, Gary D. |
1) Because I now return angular units expressed in milliradians instead of degrees, line 198 needs to be changed from: heading = Gyro_Angle()*PI_MRAD/180L; to: heading = Get_Gyro_Angle(); 2) The programming interface was expanded and many functions were renamed. To fix this, I would just drop the new version of gyro.c/.h into your build directory and let the compiler find the deltas for you (there will only be a few). -Kevin |
:-) Gary |
-Kevin |
#10
Kevin, the gyro code has worked fine for us. We are able to track heading, and stick to a heading. We arent using the scripting, for lack of need.
As soon as we get our encoders in, I will post how the PID works out. |
#11
-Kevin |
#12
Is the BEI gyro really illegal to use? I am a rookie engineer this year and see that Kevin Watson has included configuration for it in his navigation code. Our team coach handed me the sensor, from last year's kit, and I have begun wiring it in. IF illegal, why? I saw that the BEI gyro can be purchased on the web. Wouldn't a team just
count it's price in the electronics price of it's parts or is there some rule about past electronics parts. It seems awfully silly to have to not be able to reuse last year's electronic parts. |
#13
I have tried the ADXRS300EB and the BEI gyrochip AQRS-0075-xxx (two different units) with some problems. I have measured a nominal 2.5 volts for both sensors and when physically swinging both gryo's in opposite directions see the voltage swing up/down as expected. So, from a gross standpoint, gyro's are operational. The software outputs a gyro bias of 4144? When, I swing the gryo 180 degrees in one direction, slowly, and return to zero I cannot get the gyro to indicate zero. Have set #define to ADXRS300EB setting and #define to AQRS0075 and played with scaling factor without success. Turned out long term Bias calculation - close to short term bias. After powering up and gyro reading 0 degrees for 4 or 5 samples, I swing the gryo 180 degrees slowly and return to zero. Any suggestions, Kevin. BTW, I really believe the ADXRS300 EB scaling is not 5 mv /degree/sec but 7.5 mV/degree/sec. Plus/minus 300 degrees over 4.5 volt range, is 300 degrees over 2.25 volt range (2.5 to 4.75 or 2.5 to 0.25 volts). or 2250 mV/300 degrees which is 7.5 mV/deg. Scaling for Plus/Minus 75 degrees/ second is 30 mV/deg/sec Scaling for Plus/Minus 150 degrees/second is 15 mV/deg/sec scaling for plus/minus 300 degrees/second is 7.5 mV/deg/sec |
#14
Code:
static unsigned char old_io3_state = 1;
static unsigned char old_io4_state = 1;
// did user just push the bias calculation button?
if(rc_dig_in03 == 0 && old_io3_state == 1)
Start_Gyro_Bias_Calc();
printf("Calibrating...\n");
// did the user just release the bias calculation button?
if(rc_dig_in03 == 1 && old_io3_state == 0)
Stop_Gyro_Bias_Calc();
Reset_Gyro_Angle();
// did user just push the reset button?
if(rc_dig_in04 == 0 && old_io4_state == 1)
// reset the gyro angle to zero
Reset_Gyro_Angle();
// save the current button states
old_io3_state = rc_dig_in03;
old_io4_state = rc_dig_in04;
-Kevin |
#15
32768(2.5 volts) -32282(Bias)=486. 486/64 = 7.59 a/d counts * 5 mV/count = 38 mV above 2.50. Null bias should equal 2.538 volts. Verfied with DVM. Hooray! Sampling rate was 1600 Hz, samples per update rate set to 64, ADXRS300EB utilized, #define TENTHS__OF_A_DEGREE. #define GYRO_CAL_FACTOR = 1000/1000 (no change). Simple 180 degree spin test executed. Learn bias at 0 degrees, verify for 4/5 readings on terminal that angle = 0 degrees. Next, spun gyro 180 degrees - reading about 900 counts (90 degrees * 10 counts/degree). Return to 0 degree position - read 0 counts (plus/minus 30 - remember, very coarse test). Next, tried the GEI GYROCHIP AQRS_00075. Changed the #define GYROCHIP_75 at top of gyro.h. Same spin test gave similiar results. Spun 360 degrees and back - similiar results. Sampling rate 1600 Hz, samples per update rate equal 64, #define TENTHS_OF_A_DEGREE, #define GYRO_CAL_FACTOR = 1000/1000 (no change). Quote:
Did you work some new magic in the new 01/30/05 software release, or do you think the 1600 Hz, samples = 64 is what made this work? I did not have time last night to experiment with various settings. I tried the 01/22/05 software and found my head bloody from beating it against the wall to make it work. BTW, thanks for responding to previous e-mail and publishing 01/30/05 release. |
| Sourceforge for Code Repository and other stuff | SilverStar | Programming | 9 | 15-01-2005 21:16 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Wierd gyro code problems...pls help | Salik Syed | Programming | 4 | 14-03-2004 01:29 |
| Infrared Beacon and Sensor Diagnostics Code Released | Kevin Watson | Programming | 3 | 25-02-2004 17:50 |
| gyro code | odin892 | Programming | 2 | 08-04-2003 14:50 |
