Go to Post Removing too much of the challenge removes too much of the accomplishment when you solve the problem. Removing too much of the challenge removes too much of the innovation in the solutions... removing too much of the challenge removes too much of the fun. - dlavery [more]
Unread 17-01-2005, 22:51
Collmandoman Collmandoman is offline
Post-A-Holic
Rookie Year: 2000
Collmandoman has a spectacular aura aboutCollmandoman has a spectacular aura aboutCollmandoman has a spectacular aura about
Robotic arm joints
Anyone know of any good texts on strong arm joints? thanks
Unread 17-01-2005, 22:59
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
Re: Robotic arm joints
who needs text. go buy ducttape.
*edit* nevermind. just remembered ducttape was illegal in FIRST
Unread 17-01-2005, 23:23
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Are you talking about rotating joints or a joint of a different kind?
Either way, in general what i always do first is just start looking through the gallery here on chiefdelphi at robots. Lots and lots of arms on robots. If you find something interesting send a message to the team that made it.
Team Website
OWI Robotic Arm cvhsrobotics Technical Discussion 2 18-01-2005 00:34
Telescopic Arm and grabber design help M. Hicken Technical Discussion 13 17-01-2005 12:56
pic: Robotic arm CD47-Bot Robot Showcase 2 14-09-2003 17:37
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
