Go to Post By the way, safety glasses are so in style now, :) - LightWaves1636 [more]
Unread 18-01-2005, 14:48
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
using alternative compiler
how can i use the devc++ compiler to work on the robot code?
are there any special parameters i need to use?
were having some problems with MPLab.......
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 18-01-2005, 15:06
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: using alternative compiler
devc++ uses GCC as the compiler, which will not compile for our pic18 target. It may be possible to change the default compiler to use Microchip's C18 as the compiler. Then you could use devc++ as your IDE and C18 as your compiler.
Are you sure the problem is with the MPLAB IDE and not with the C18 compiler?
Unread 18-01-2005, 15:30
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
yeah i already figured out that i would have to change the compiler, i kindof did that, but i was hoping that maybe someone would tell me what the minimal configurations are, like what flags to send to the compiler, so that it works and i'll take it from there......
-Paraphrasing JFK
IMPORTANT regarding the new C Compiler dlavery General Forum 12 14-01-2005 05:05
Makefile and stripped down compiler Venkatesh Programming 0 09-01-2005 18:55
Linux C18 compiler? Servo888 Robotics Education and Curriculum 1 13-12-2003 01:27
C compiler for 2004 Tim Skloss Technical Discussion 11 05-11-2003 22:02
