Go to Post They truncated our conference title. We are not showing the movie "Finding NEMO" - RoboMom [more]
Unread 18-01-2005, 19:29
Ben Piecuch Ben Piecuch is offline
Bengineer
Rookie Year: 2000
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Torsional Stiffness of Extruded Aluminum
Has anyone found data on the torsional stiffness (or polar moment) of Extruded Aluminums? (8020, Bosch, etc...) I'm trying to compare a 2"x1" x1/8" box section to a similarly sized extruded piece. Surprisingly, the bending strengths and weights are very similar, which is swaying me toward the extruded piece. However, this piece will probably have some torque applied to it's end, and my feelings are that the extruded piece will have a fair amount of twist.
If I don't get any data from here, I'll try to rig something up myself and post some numbers here. Thanks.
Bengineer
Team 228
Unread 18-01-2005, 22:28
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Re: Torsional Stiffness of Extruded Aluminum
I don't have the numbers but what i can tell you is that it should resist torsion.
A 1 sided piece of aluminum(flat bar) resists bending in one direction
A 2 sided piece of aluminum(L bar) resists bending in two directions.
A 3 sided piece of aluminum(U channel) resists bending in two directions and torsion.
A 4 sided piece of aluminum just does that better.
If you have a piece of each of those shapes you can try it. The difference is pretty obvious.
Team Website
Unread 18-01-2005, 22:43
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Rookie Year: 2000
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Torsional Stiffness of Extruded Aluminum
Bengineer
Team 228
The polar moment of inertia of a shape is the sum of the intertia in two normal directions.
For instance, with a cylinder, Ix and Iy = pi*D^4/64
the polar moment is Ij = pi*D^4/32
I'm reasonably sure the give you the moment of inertia, so you can just double it for a symetrical piece and it will be the polar moment. In your case, you just add the Ix and Iy values.
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 19-01-2005, 21:55
Gary Bonner Gary Bonner is offline
FRC #3974
Rookie Year: 2000
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Item has torsion specs for their extrusions. You have to register on their website to get to the e-catalog. www.itemamerica.com
where can I get info on extruded aluminum? SCYTE16 General Forum 21 13-01-2005 14:23
Mini extruded aluminum Ravi U Technical Discussion 7 17-01-2004 02:12
Difference in aluminum archiver 2001 1 23-06-2002 23:49
