Go to Post Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together. Nothing works and nobody knows why. - CalTran [more]
Unread 19-01-2005, 12:56
psychoCHIPMUNKK's Avatar
psychoCHIPMUNKK psychoCHIPMUNKK is offline
Technical Manager
#0241 (Last Minute Fix)
Team Role: Driver
psychoCHIPMUNKK has a little shameless behaviour in the past
Send a message via AIM to psychoCHIPMUNKK Send a message via Yahoo to psychoCHIPMUNKK
Exclamation Emergency Vic 884 Help Needed
We've got a slight problem with our test frame. We've built the kitbot and were attempting to wire it, but for some reason our 2 new 884s will only flash orange. The other 2 old ones work fine. We've replaced the cable 3 times (it's one of the yellow split ones) and switched the port around, and for some reason it still wont work. We've taken the tabs off the new ones, and made sure they're in far enough, but nothing has worked yet. Does anyone know what to try next?
Team 241
We fried an 884 Andrew Electrical 13 17-08-2003 23:02
