Go to Post I am a geek. - Andy Baker [more]
Unread 19-01-2005, 18:16
Orborde Orborde is offline
FRC #1747
Orborde has a spectacular aura aboutOrborde has a spectacular aura about
Send a message via AIM to Orborde
2-Segment Arm Control
I expect a lot of people to be using an arm of some sort this year, and on our team, at least, controlling the thing looks to be interesting, to say the least. We're using a 2-segment arm this year, assuming we don't run into major problems involving leverage, and this idea popped into my head for controlling the thing.
Given some target coordinates (Xt, Yt), relative to the base of the arm, some simple measurements, and two motors (overpowered servos, really) that can be set to any angle, this algorithm should move the end of the arm to where it is needed quickly and easily.
The target coordinates (Xt, Yt) could be set by a joystick or two that moves the target point around at a constant rate.
Pseudocode:
Set the target coordinates (Xt, Yt)
(see diagram)
A = Length of first arm segment
B = Length of second arm segment
C = sqrt(Xt ^ 2 + Yt ^ 2)
D = sqrt((Xt - Xb) ^ 2 + (Yt - Yb) ^ 2)
E = sqrt(Xb ^ 2 + Yb ^ 2) <- See below
Using the Law of Cosines...
b = invcos((A ^ 2 + C ^ 2 - B ^ 2) / (2 * A * C))
c = invcos((A ^ 2 + B ^ 2 - C ^ 2) / (2 * A * B))
d = invcos((C ^ 2 + E ^ 2 - D ^ 2) / (2 * C * E))
Finally, set the motor angles with your algorithm of choice.
Motor 1 Angle = b + d
Motor 2 Angle = c
Notes:
E is defined as it is in order to ensure consistency between it and Xt,Yt. It may be easier to simply measure it; I'm not sure. This may be an optimization that can be done without any problem; I was queasy about it. On second thought, it should be fairly easy to obtain the (Xb,Yb) coordinates since, as laid out, they're right up against right-angle edges of the frame.
Probably the most irritating part of this from a programming standpoint is getting useful math functions. Anyone know where I could find the ones I need?
Questions? Comments? Grievous errors? Feel free to lob any and all of them at me.
Unread 20-01-2005, 01:40
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Team Role: Leadership
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Re: 2-Segment Arm Control
Here is a good CORDIC math library I've found. Team 296 made it, so thank them. The only thing I added was a power function. Its a simple algorithm, but it made my code cleaner. Read the comments, for they explain the return type. Everything is integer math (Longs, I believe), so the numbers represent obscure fractions of a degree. Read the comments and you'll do fine.
-Tony K
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
**FIRST EMAIL**/Public Television airs ZOOM segment featuring FLL team from 2003 Miss miketwalker FIRST E-Mail Blast Archive 1 27-05-2004 01:08
Neural Control of Robot Arm Leo M Math and Science 2 29-03-2004 13:46
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
