So, since this is probably the time of the season where teams are really starting to realize their designs and doing some weight calculations to see how close to the limit you are, or if x motor can power y device, or if your robot is going to tip over, I thought it would be nice to have one common location for weights for different devices. I'll start with what I have so far, and if people add to the list below my post, I will update this first post with the new parts. Also, I will show parts as verified if somebody confirms a weight. At least it will give you a starting point for weight watching (tm?).
Can anybody show me how to do a table, if possible? BTW...NBD is Nothing But DeWalts Also, at the end, I'm listing items I am going to try and find weights for by searching or weighing myself when I get to the lab tomorrow. But, if you have any information about anything, I will add it to the list. Thanks! Format: Part name, Numeric Value, Units, Verified, Note Pillow Block Bearing, 12.9, Oz., Not Verified, Kit part FAFNIR 1" Sq. Aluminum Tube 0.062 Wall, 0.274, lbs/ft, Not Verified, Alro Catalog 1x2" Aluminum Tube 0.125 Wall, 0.808, lbs/ft, Not Verified, Alro Catalog 3/4" Aluminum Round 0.125 Wall, 0.391, lbs/ft, Not Verified 1/4" Aluminum Plate 6061-T651, 3.63, lbs/sq ft, Not Verified, Alro Catalog 1/8" Aluminum Plate 6061-T6, 1.764, lbs/sq ft, Not Verified, Alro Catalog 1/16" Aluminum Plate 6061-T6, 0.889, lbs/sq ft, Not Verified, Alro Catalog Battery, ~12, lbs, Not Verified, Weight varies slightly battery to battery Battery Connector Compressor CIM Motor CIM Motor NBD Fisher Price Motor F-P Motor NBD F-P Motor w/ Gearbox Globe Motor Globe Motor NBD Mabuchi Motor Window Motor Van Door Motor Clippard Tank RC Spike Victor Power Dist. Block Solenoid Valve 6 AWG Wire 10 AWG Wire LED's #35 Chain #25 Chain 5/8" Steel Shaft 3/8" Steel Shaft 3/8" Aluminum Shaft #35 Sprockets #25 Sprockets Wheels and Tires 5/8" Bearings 3/8" Bearings Last edited by Don Wright : 01-20-2005 at 07:05 AM. |
Re: Robot Part Weight List
http://www.cyberblue234.com/cyberblu...htdatabase.xls |
I can't seem to be able to open that Excel file... It just locks up. I did download it to my machine before opening too...
Here's what I can contribute for now. These were weighed on our electronic scale, accuracy is probably +/- .1 lb.
AndyMark Shifter w 2 CIM 9.9 lbs Van Door Motor 2.7 lbs ND Window Motor 1.9 lbs Jideco Window Motor 1.5 lbs Globe Motor w gearbox 1.1 lbs Air Compressor 4.6 lbs Battery 12.7 lbs |
| How much planning goes into your robot? | Jnadke | General Forum | 41 | 01-29-2006 09:29 PM |
| What scales to weight robot? | chocolateluvrlr | General Forum | 41 | 04-08-2005 09:43 PM |
| Robot size and weight | Covey41 | Rules/Strategy | 8 | 01-10-2005 10:32 AM |
| Best Robot Ever(again) | Corey Balint | General Forum | 26 | 08-04-2004 11:03 PM |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 03-19-2003 01:30 PM |
