Go to Post Intent is determined by those that are doing, not those that are watching. - meaubry [more]
Unread 20-01-2005, 11:17
team1307 team1307 is offline
team1307 is an unknown quantity at this point
Send a message via AIM to team1307
USB Joystick to DB15
I have a nice set of USB joysticks that I would like to use. The problem i'm having is finding a converter that is USB to DB15. I found plans online that should let me do the conversion it it was usb to DB9 but that doesnt help too much. http://www.lennard.net.nz/electronics/usbtors232.html
I'm not sure It would work because of the voltage problem. I also would like to know if drivers would be an issue. This mod requires drivers, but i'm not sure if that would matter during integration with the robot controller. Has anyone tried this before? Did it work?
Remember, I'm trying to convert a USB Joystick to a DB15 joystick.
Thanks a lot and see you at the comp.
