Go to Post Earlier this week it took me a little bit too long to realize that the reason my pen wasn't writing correctly was that it was actually a screwdriver. I'm going to have to ask for a few nights of honest sleep before signing off on a report. - EricVanWyk [more]
Unread 20-01-2005, 13:21
Team ICE #1611 Team ICE #1611 is offline
Team ICE #1611 is an unknown quantity at this point
I Need Help With An Arm
We are rookie team and could use some suggestions and possibly some help for designing an arm for our robot this year. We have come up with a few ideas but we would like to know what others are doing so we can get an idea and build off of it. Our idea for an arm right now is being based of the forklift and use pneumatics and/or motor to power it. If anyone has another idea for us or can help us with our own we could sure use it.
Unread 20-01-2005, 13:25
team222badbrad's Avatar
team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Rookie Year: 2000
team222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond reputeteam222badbrad has a reputation beyond repute
Send a message via AIM to team222badbrad
Re: I Need Help With An Arm
I would say the easiest thing to build a forklift with is 8020. www.8020.net
This depends on how much equipment/resources you have build with.
If you do a forklift you definitely need to use a motor to move it up and down.
You can use either cable, chain, or a rack & pinion to move it up and down.
You will also need 3 stages to obtain the height you need to reach the center tetra.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 20-01-2005, 13:36
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Rookie Year: 1999
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
There's another thread on here http://www.chiefdelphi.com/forums/sh...threadid=33082
In it is a video of team 121 documenting there progress. They apparently didn't mind showing there concepts to the world. So I doubt they would mind you taking the liberty of the concept shown. You should probably ask anyway. But personally I think the wood 2 joint arm mock-up concept is a great idea, and could be built pretty easily. It's my opinion to stay away from elevators. I think they're too slow and top heavy. What ever you do, keep your center of gravity low. There's threads on telescoping arms, which could be a great easy way to go also.
All that said, if you're feeling like an arm may be more than you're ready to build. There are some excellent defensive strategies that you could design to, that let you place tetras inside of goals instead of on top, and focus more on a good drive system to block and offend. Every alliance will need a good bully. It's also my opinion that the kit is so good, this year it may boil down to the best drivers, and not the equipment. Every year has shown you can do a LOT with nothing more than a rolling chassis, and this year will be no different. I would focus more on getting done quick and giving your drivers as much time as possible to get used to it.
www.179swampthing.org
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Team Role: Leadership
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
Some things to think about off the top of my head:
center of mass - Make sure to make your forklift as light as possible relative to you drivetrain; otherwise your robot will be very top heavy and trip.
Pnumatic vs. Motor: Pnumatics cannot give you precise control of the position of the arm. With pnumatics you are either extended or retracted (and maybe a middle position). Also, with a large cylinder you may run out of air if you use it too often. On the other hand pnumatic implementations tend to be lighter then motors because you can use on compressor to drive a lot of actuators. Also, you do not have to deal with a converting rotational motion to linear. If you use chain and sprocket, make sure the chain is big enough and tensioned enough so that it will not slip. If you use cables make sure they do not jam/rip on edges.
Balanced loads: Make sure that you do not drive your forklift from only one side (assuming it has sides). If you do that, it may have a tendency to get jammed becuause it will tilt.
good luck
Alex
President
Team 1072 Harker Robotics
Unread 20-01-2005, 14:37
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Some other general advice from one rookie to another. Think about the following:
1) The "arm" really only needs to extend about HORIZONTALLY 2.5 feet beyond the front edge of the robot in order to be hovered over the center of a goal
2) The "arm" may or may not need its own independent rotating/turning mechanism depending on how well you build your drive base assembly. Namely, can you position a tetra by using a "stiff arm" and rotating the whole robot at its base?
3) The arm needs to get to three different VERTICAL positions only. One is floor-height to pick-up a tetra on the field (either the vision tetras or one that got dropped), second is a tetra at "loading" height (manual load or auto-load) and the third height is the height required to TOP another goal or stacked tetra. No need to get to any other heights.
4) The robot "arm" most likely needs to be able to judge by itself when it is safe to "drop" a tetra onto a goal. It will be very difficult to see if the robot is in position from the driving station.
So.....think about your arm in a cast. What MINIMUM number of functions does the arm need to have?
The THUNDER just keeps getting LOUDER in 2008....
Team 1511 now supports over 15 FLL teams
RollingThunder....Winner of the 2007 Chairman's Award at Finger Lakes Regional and Spirit Award at Boston.....Winner of 2006 Finger Lakes Regional Engineering Inspriation and Boston Imagery awards.......Winner of 2005 World Championship Rookie All-Star (plus FLR Rookie All-Star, Buckeye Top-Seeded Rookie, GTR Champion, Spirit, and Inspiration)
"Gracious Professionalism is a WAY of life".....
2-Segment Arm Control Orborde Programming 1 20-01-2005 01:40
WHich motor to lift and for arm thoughtful Motors 8 25-02-2004 10:34
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
