Re: Using Extruded Aluminum to telescope.
I posted a picture on CD of our 2004 robot's sliding nylon piece of our scissor lift. We manufactured it.
http://www.chiefdelphi.com/forums/pi...&quiet=Verbose |
Three years ago my team Had to manufacture our own sliders out of nylon, it was tedious work, but they held up well. You want to also watch out for how you have your mast arranged, because if you use a lot of cable and oulleys the upkeep on it is horrid
Do you use it as a spring to extend the arm, then pull it back some other way? Or do you push with it? Or what? Can you say where you get it, what product? Thanks |
We have a design that allows us to use the "track" on the tape to both extend and retract the arm with a motor driving it. We drive the arm up the tape more or less. Below are the best 2 picture I could find on our website. We have used this mechanism in 98, 99, 01, and 03. I'll see about getting some better pictures of it at tonight's meeting. http://www.swindsor.k12.ct.us/Highsc...t_Pit_engpoint http://www.swindsor.k12.ct.us/Highsc..._Pit_fromabove Edit: Forgot the URL of our homepage. http://www.swindsor.k12.ct.us/Highsc...s/clubs/first/ Last edited by Peter Matteson : 03-02-2005 at 12:01. Reason: added URL |
Cybersonics has been making telescoping structures out of extrusions for years, mostly 8020 1010, though we used Bosch 2020 last year. Instead of using linear bearings, they just interlock parallel extrusions and apply a little lithium grease.
The engineer in me cringes every time I look at how we do it, but it's simple, it works and is very light weight. I think the key to this working is the hard anodized coating on the aluminum keeps it from galling. Needless to say, I wouldn't expect this to work for a real long time, but the only problem we've had (besides cringing engineers) is when the strut gets bent, but that would be a problem with linear guide bearings, too. |
| Torsional Stiffness of Extruded Aluminum | Ben Piecuch | Technical Discussion | 3 | 19-01-2005 21:55 |
| where can I get info on extruded aluminum? | SCYTE16 | General Forum | 21 | 13-01-2005 14:23 |
| Mini extruded aluminum | Ravi U | Technical Discussion | 7 | 17-01-2004 02:12 |
