Go to Post We have tried doing the cha-cha slide on the airplane, but that went away very quickly - it seems that the pilots don't like all the movement in the plane. - Carol [more]
Unread 20-01-2005, 21:59
eatthafoodtina eatthafoodtina is offline
eatthafoodtina is on a distinguished road
Favorite Joystick Setup? We're new
What is the preferred setup of the two joysticks for your robot? Do you like to have one for driving and one for arm control? Or do you like to have one run the right side wheels and the other run the left side. Then just use the buttons for arm control? Whyich is easyer? I would like to have one per wheel so you can make one go forward and the other the opposite making for a much tighter turn.
But we are newbies so what is the best method?
P.S. I have read about the singal stick script but I never thought I found the one that would do what we wanted.
Thanks for the help!,
Jason
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
