Go to Post Never, Never tell a prospective mentor what the actual job description is. You need to get them hooked first. :D - BJT [more]
Unread 01-22-2005, 10:13 PM
Jason Rudolph Jason Rudolph is offline
Alumni of 168
Rookie Year: 1998
Jason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud of
Send a message via AIM to Jason Rudolph
Incorrect Information in Update #3
I know it's been out for a few days now, but I've been stuck in the tudio all week and missed it. The information given in update #3 is not enntirely correct. Specifically, hardly any venues use sodium vapor lighitng anymore. In fact, if any kind of broadcasts are done from the venue, then there is absolutely no way this would be the lighting in the venue. A majority of venues now use Metal Halide discharge lights as their source, which has a color temperature more in the 5000Kelvin range, but, more importantly have a vastly superior color rendering index (CRI) of about 60-70 on average, versus about 20 for sodium lights.
Additionally, the fields at FIRST events typically are NOT light using the venues lighting alone, if at all. There is usually a supplemental lighting package provided by a production company, which ususally consists of either source four pars made by ETC ( http://www.etcconnect.com ), or StarPar by altman. ( http://www.altmanltg.com/ProductDisp...&categoryID=16 )
Thee lights are readily available from your local stage lighting comany for rental. The suggestion FIRST made of buying the halogen work light is a good one, but remember when you use it, that you need to turn off any other light sources in the room in order for it to be effective.
Hope this helps......
Jason Rudolph
Lighting Designer/Programmer
Unread 01-22-2005, 11:29 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Incorrect Information in Update #3
I don't beleive that FIRST meant that the venues used sodium lighting, but that most high school gymnasiums do, which would be a standard place to test the robot.
Unread 01-22-2005, 11:55 PM
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
I have to disagree with part of the post. Yes, many of the newer competition venues (e.g. the Siegel Center at the VCU/Richmond Regional), or those intended for broadcast environments (e.g. the Great Western Forum at the SoCal Regional) will have metal halide lighting. However, many of the older venues in which regional competitions are held were never intended to source broadcasts and still use sodium vapor and mercury vapor lighting (e.g. the Halsey Field House for the Chesapeake Regional and the Matthaei Field House for the Detroit Regional). In addition, many of the events - particularly the "low-cost regionals," which will be more than half of the events this year - will not have any supplemental lighting, and the entire lighting environment will be determined by the house lights.
A quick initial survey of all the regional venues with FIRST makes me believe that the light levels and mean color temperatures from event to event will be all over the place. I will attempt to get more details on lighting environment for each of the competition venues from Steve Sargeant and provide that information. But the short, simple message to all the teams is "bump up the light levels in your test environment A LOT, and be prepared to pay a lot of attention to the calibration numbers provided by FIRST for each event."
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 01-23-2005, 01:13 AM
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
I know that the lights in the Purdue Armory (Boilermaker Regional) burn with a distinct golden-orange hue; however, there is also a lot of natural light in the daytime. I don't know if this regional is "low-budget" or not but expect the lighting conditions to be all over the place here. Basically, be sure to calibrate your cameras on Thursday!
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 01-23-2005, 12:41 PM
Alumni of 168
Rookie Year: 1998
-dave
I think that this information is really going to be critical, as if the venue does use sodium lighting, without any supplemental lighting package, then those cameras are going to be VERY dificult to use, especially when discerning between yellow and red.
Mercury vapor isn't too bad, but sodium lighting + cameras = bad stuff.....
Unread 01-23-2005, 06:27 PM
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
The bit of info all should glean from this discussion is that the lighting is going to vary in color temperature and intensity across the playing field. If supplemental lighting is brought in, it is likely to be color corrected but the house lights will still be on and affecting the overall color temperature. In any case it will not be possible to flat light the entire playing field. In addition, nationals will play in a venue where there is some daylight available and depending on weather and time of day, it will produce variables most regionals will not contend with. Expect there to be color differences that might affect the response of the camera. Do not be fooled by your own vision. Even those that are experienced in noting the subtle differences in color cannont predict what the camera sees as green or yellow.
Jason, do you always work out of NY and on TV production?
Al
WB9UVJ
www.wildstang.org
________________________
Unread 01-24-2005, 12:26 AM
Alumni of 168
Rookie Year: 1998
I actually work out of Miami, at the Network headquarters for Univision (largest spanish television netowrk in the world)
I am a lighting programmer/designer and also the head technician. I run the lights on Sabado Gigante (one of the longest running shows on television) and Don Francisco Presents. I also am involved with our special events, one of which I am currently prepping for, which is basically the Grammys for the spanish world, which will air live on february 24th.
All this and I don't speak spanish, go figure......
Unread 01-24-2005, 08:14 AM
Unsung FIRST Hero
Rookie Year: 1996
Spanish, English, it's all TV. I work for WTTW in Chicago as Broadcast Engineer. I do get a call every once in a while to repair the DeSisti battens or dimmer packs when they go bad.
Al
WB9UVJ
www.wildstang.org
Unread 01-24-2005, 11:38 AM
Alumni of 168
Rookie Year: 1998
I seem to have reembered there was a boradcast engineer roaming around on here somewhere, now I remember!
**FIRST EMAIL**/Important Manchester Kickoff Information Rich Wong FIRST E-Mail Blast Archive 4 12-21-2004 05:02 PM
**FIRST EMAIL**/Important December 3rd Deadline Information - Please Read! dez250 FIRST E-Mail Blast Archive 1 11-23-2004 01:35 PM
**FIRST EMAIL**/Important Information for All Championship Teams! Jeremy Roberts FIRST E-Mail Blast Archive 0 04-09-2004 09:12 PM
**IMPORTANT FIRST EMAIL**/Robot Ship Extension News with Season Information and Upda miketwalker FIRST E-Mail Blast Archive 0 02-13-2004 06:02 PM
