Go to Post 32% of the teams in any division will be or could be in eliminations. And any one of those could be YOU. If you aren't ready, you will be eliminated. If you are ready, you greatly increase your chances of winning. - EricH [more]
Unread 23-01-2005, 19:31
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
LCD wiring to Program port
I am in the process of wiring up a BPP-420 LCD to the Program port on our RC for use with Kevin Watson's serial port code. I have pin 3 of the serial connector connected to the data pin on the LCD, I have the +5 pin from a digital I/O connected to the +5 pin on the LCD, and I have pin 5 and the ground from a digital I/O connected to the ground pin on the LCD. Is this the proper wiring? I couldn't find an actual pinout of the Program port, so I just went with the RS-232 standard, but I want to make sure it's right before I power it up.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
The Hall Effect sensor wiring? LaughingJack Electrical 11 21-02-2005 13:35
Electronics Board Construction/Design zdeswarte Electrical 10 28-01-2005 00:09
Neat & Organised Electric Wiring thoughtful Electrical 30 13-12-2004 22:46
Help wiring Line sensors magical hands Electrical 1 18-02-2004 10:17
Optical sensor wiring with the EDU Robot Geoffrey4283 Electrical 3 15-01-2003 21:03
