Go to Post After all, life is what you do outside of FIRST. No wonder it's so short. - Vashts6583 [more]
Unread 23-01-2005, 20:39
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Modifying CIMs to implode?
OK, so this question in the Q&A system has me intrigued:
Q 1330: Under the restrictions specified in <R31>, is it permissible to turn down the housing/case of the CIM motors to reduce weight?
The answer from FIRST has not been posted yet, but it has me wondering - is any team actually contemplating turning down the outer walls of the CIM housing? Does anyone expect to be able to remove any meaningful amount of weight without destroying the characteristics of the motor? This would seem to be a very bad idea in terms of maintaining the structural integrity of the motor, and a potential hazard. Or am I being overly conservative? Anyone have any thoughts about whether this should be/will be permitted?
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 23-01-2005, 20:41
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: Modifying CIMs to implode?
That's about as bad as "Can we drill holes in our pneumatics to save weight?"
Can't possibly see how FIRST will allow this
2001-2004: Team 100
2006-Present: Team 254
Unread 23-01-2005, 20:45
Charly's Avatar
Charly Charly is offline
AKA: Ricardo Martins
#0714 (Super Panthers)
Team Role: Electrical
Charly is an unknown quantity at this point
Send a message via AIM to Charly
Although I'm not one for the mechanical aspect of things, I have to agree with you, it seems like a hazard.
Team 714 Robotic Design Captain/Electrician
Winners of the 2004 New Jersey Regional Chairman's Award!
Competitions we'll be attending in 2005: NJ Regional, Florida Regional, Championships!
Unread 23-01-2005, 20:51
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Teams have done it a small amount before to remove the black paint and have a shiny finish.
Unread 23-01-2005, 21:04
dlavery's Avatar
Curmudgeon
Rookie Year: 1996
I agree that it will probably should not be allowed, but wondering what rule they might use to justify a "no, you can't do that" response.
Unread 23-01-2005, 21:11
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Rookie Year: 2000
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Going from questions similar to this in the past... it would seem to be legal... because it specifies that you cannot modify the internal electronics of the motor, but you can modify the housing... hrmm... maby this is one of those times where they give you enough rope to hang yourself.... because as the steel was removed it would also mess with the magnetic flux inside the motor and probably lower efficiency, similar to removing the metal band on the FP motors.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 23-01-2005, 21:15
Cory's Avatar
AKA: Cory McBride
It might be legal with how the rules are currently stated, but Jeff's example of 2003 and 68 also read that their robot would be legal (or in a grey area, at the very least) until FIRST specifically outlawed it.
I think this would be a similar case, given that it would be a safety hazard and just plain dumb
2001-2004: Team 100
Unread 23-01-2005, 21:22
Karthik1's Avatar
Karthik1 Karthik1 is offline
830 Alumni
AKA: Karthik Chokkaram
FRC #1504 (Desperate Penguins)
Karthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to all
What if they want to change the material of the housing rather than make holes in it and destroy it's structural integrity, although neither are worth the trouble. If you want to loose weight I am sure there are plenty of other places where you can loose it.
"freedom is voluntary self control” Mahatma Gandhi
Unread 23-01-2005, 22:50
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
This has been done. I remember very cleary seeing shiny CIM motors on 190's bot last year. I asked a friend of mine who was on the team why the CIM motors looked so skinny. He pointed out that <R31> allowed for modification of the motors structurally, not electrically. I agreed that it was legal, but wasn't sure if it was worth it. I forgot how much weight they lost with this. Obviously, they competed with them, so if anyone questioned the legality of the modified motors, it didn't go anywhere.
My guess is that FIRST will allow it, again. Of course, my preference would be to just not use all 4 of those heavy guys, but alas..
I don't like heavy stuff.
-Andy A.
Unread 23-01-2005, 22:54
Arefin Bari's Avatar
Arefin Bari Arefin Bari is offline
AKA: Ari
FRC #0108 (SigmaC@T)
Arefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond repute
Send a message via ICQ to Arefin Bari Send a message via AIM to Arefin Bari Send a message via MSN to Arefin Bari Send a message via Yahoo to Arefin Bari
I have to go with what Dave and Cory said. Its hazardous.
-Arefin.
Unread 23-01-2005, 22:57
dez250 dez250 is offline
54... What a good number!
Rookie Year: 2000
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
-Andy A.
Maybe the reason why FIRST "allowed" it is because they did not know about it. If you look at one of the rules [the number escapes me now] you can not modify the integrity of a motor. This means you cant modify it physically or electrically. You can remove the gearbox on the fisher price motor and globe motor or alter them as they are not considered integral this year. But if you try to "skin" a CIM motor i would suggest you to have extras as many inspectors this year should have you to replace it.
-Michael Dessingue
Unread 23-01-2005, 22:58
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
To answer the above post, let me cite R31, which says nothing about the integrity of the motors:
    1. It is acceptable to modify the mounting brackets and/or other structural parts of the motors (output shaft, housing, etc.) as long as the electrical system is not modified and the integral mechanical system of the moving parts (bearings, bushings, worm gear output stages, etc.) is not changed or removed.
We are modifying the housing, not integral moving parts.
The weight loss was not terribly significant (around .1 pounds), but it helps with heat dissipation. Just make sure to put some clearcoat or paint on them after turning them down, as unprotected steel will rust.
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Unread 23-01-2005, 23:04
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
My guess is the answer will be NO modification of motors is allowed. I do not think that they can save enough weight to make it practical to turn down the case, the majority of the weight is in the armature, shaft and magnet assy anyway. My guess is the case is about as thin as it could be now, the company is afterall, trying to make a profit and have already made the determination as to the minimum material the case needs. If the answer comes back that the case can be modified, I can tell you we will experiment with case mods just to be sure that there is no real advantage.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 23-01-2005, 23:12
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
While you're right that the weight savings aren't significant, R31 seems to clearly state that modification of the housing is okay, as ahecht pointed out above. Do you have a counterpoint from the rules that would indicate why a team couldn't do this if they really, really wanted to?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
  #15   Spotlight this post!
Unread 23-01-2005, 23:19
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
You could probably remove the paint easier with sand paper, if that was your goal.
See you in DC!
Anyone modifying the stock gearboxes? Swampdude Technical Discussion 17 04-02-2005 13:15
Modifying Default code great_one411 Programming 7 16-02-2004 10:32
where to buy cims Brawler006 Motors 2 26-01-2004 13:16
Gears for CIMs Brawler006 Motors 5 18-01-2004 09:46
modifying sprockets gail OCCRA 3 05-10-2002 12:13
