Re: Modifying CIMs to implode?
Has anyone tried any other modifications to help heat dissipation? Are there any places you can safely put holes in the casing to get some air flow inside?
I am not going to test the rule or disrespect the advice of motor techs on this list. My follow up is in regards to the reported gain in radiational cooling by removing the black paint by sanding to the bare metal?
Our team has never modified a motor or mount but the comment about bare metal verses paint is of mild interest. Does this violate the rule or even the spirit of the rule? I would guess that one could even add paint to the housing as part of some color scheme on the robot... |
I think the rule is clear that removing the paint does not change the basic ops of the motor. But like I have said many times before, if the Chalupas (or any motor) are overheating they are a symptom not a cause. Hot motors indicate a problem somewhere else. Fix the problem. When the case of the Chalupa is hot, think what the temp might be inside at wire level. When the case is too hot to touch, you have already sacrificed molten varnish to the electrical gods. There is no coming back from this abuse and no amount of external cooling is going to save the motor. The internal temperatures, melt the varnish insulation, run the lubricant out of the bearings, distort the armature plates and shaft, and breakdown the internal adhesives used to keep all the parts in alignment. Remember that the only conduction path from armature to outside world is the shaft and bearings. All other cooling is by convection or radiation which is a slow process. |
i know this is off topic, but last year we had drill motors running to a custom gear box (like many other teams). After each round we had 2 of the 120mm fans blowing on the motors because they were almost too hot to touch. My question is, are the CIM motors as likly to get that hot? We are currently being held up by electronics problems, and we have no way to run one for 3 minutes and take the temp. Sorry if that was confusing, i know it was poorly worded. TIA |
Regarding the potential use of the Chiaphua motors as small space heaters, you may want to go back and read through this thread for some interesting observations. Within certain limits, you can expect the Chiaphua motors to experience a reasonable degree of heating during normal use. But at some point, "reasonable" becomes "way the heck too hot." The exact conditions under which this transition occurs is not precisely known, but passing the transition point is dramatic and irreversably damaging to the motor.
-dave |
If your CIM's are getting too hot, consider the obvious, your gearing is too low. If heat is a problem, the motors are working too hard. If you properly gear your drive train too run at the motors max RPM you should have no problem with overheating.
Good Luck! |
#10
I think you mean high... if your robot is geared low, it would mean it's very slow, which means it's harder to stall the motors, which creates heat.
Or maybe I interpreted what you're saying entirely backwards |
#11
Good Luck! |
| Anyone modifying the stock gearboxes? | Swampdude | Technical Discussion | 17 | 04-02-2005 13:15 |
| Modifying Default code | great_one411 | Programming | 7 | 16-02-2004 10:32 |
| where to buy cims | Brawler006 | Motors | 2 | 26-01-2004 13:16 |
| Gears for CIMs | Brawler006 | Motors | 5 | 18-01-2004 09:46 |
| modifying sprockets | gail | OCCRA | 3 | 05-10-2002 12:13 |
